new egr cooler & oil cooler
Old 02-04-2012, 09:31 PM
Frankiea87's Avatar
Frankiea87
Frankiea87 is offline
hey guys i just got a "new egr cooler and oil cooler" ... shop says they replaced both but i still notice the same oil cooler.. which i believe u can see from the front bumper of truck infront of radiator? if thats the correct location that im thinking of.... also egr cooler i dont know exactly where it is located if someone can tell me so i can look to see if its new... thanks
Old 02-04-2012, 09:44 PM
Snuggyworm's Avatar
Snuggyworm
Snuggyworm is offline
nope. u cant see oil cooler like tat. wat year and make is ur vehicle? is it 6.0 or 7.3? usually, the oil cooler is in the center valley, underneath the egr valve. u gotta remove the entire top area and u'll see the oil cooler right below in the middle of the engine.
now if urs is a 6.0, then u'll also have the oil filter housing and secondary fuel filter on top.
Old 02-04-2012, 09:45 PM
zhilton's Avatar
zhilton
zhilton is offline
That's the transmission oil cooler that you can see behind the bumper. The engine oil cooler is under the oil filter housing...and you won't be able to see it; it's inside a housing. The EGR cooler is on the passenger side of the truck to the left of the turbo under the intake. This should help a little...the bottom part of the photo has the EGR cooler pointed out.
Old 02-04-2012, 09:46 PM
Snuggyworm's Avatar
Snuggyworm
btw, egr cooler will be to the left of the oil cooler when ur looking at the engine from the front grill facing ur windshield. again, u'll have to remove the top housing to even see it.
Snuggyworm's Avatar
Snuggyworm
to the OP, wat he said. lmao.
Old 02-04-2012, 09:50 PM
Frankiea87's Avatar
Frankiea87
thanks guys... ill look at it tomorrow, by the way its an 2005 6.0 crew cab
Old 02-04-2012, 09:54 PM
zhilton's Avatar
zhilton
zhilton is offline
Pretty much everything will be in the same place. Straight behind the alternator, to the right of the oil fill spout...even in daylight you'll need a flashlight to get a good look at it. It's buried under allot of stuff.
Clearly Ford/Navistar didn't consult us when they designed this thing.
Old 02-04-2012, 10:07 PM
Snuggyworm's Avatar
Snuggyworm
ur right again, zhilton. lol.
run6.0run
11-03-2012 08:01 PM
semperstrokin
09-15-2011 09:53 AM
JonArmy
09-04-2011 08:58 PM
scameron
02-02-2009 04:15 PM
Quick Reply: new egr cooler & oil cooler
