early 99 dually / warn hubs ? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-04-2012, 07:18 PM
1999 F350 dually's Avatar
1999 F350 dually 1999 F350 dually is offline
1999 F350 dually is starting off with a positive reputation.
I want to put the Warn premium hubs on my 1999 F350 dually. The Warn website has a note for the 38826 that says "not for dual wheel applications". I have searched for an hour on this forum- found lots of questions but no real answers about this issue. How do I replace my stock auto-lockers with a manual locking hub?
Thanks in advance...
Old 02-04-2012, 07:56 PM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is online now
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
I think this issue is the fact that the warns are about an inch shorter then the stock hubs, so with the dually wheels up front it will be a long ways in there to turn it. You would have to do it with some long needle nose pliers. I just installed these on my truck in December. Love them, they work so smooth. Subscribing for what happens. If worse come to worse I would call warn and ask, I have heard there customer service is excellent.
Old 02-07-2012, 10:58 AM
Quote:
I called Warn customer service. He said that 80% of the time with DRW that there is a ring that will not allow the hubs to drop in. So, he suggested I could try it and see if it works. Not only might I be left holding some expensive hardware that I cannot use, but the time issue with replacement would be extended. Anyone out there have direct experience with this?
Old 02-09-2012, 05:18 PM
I hubs must be different on a dually then. Mine fit great. Let me know what happens, would be interested in knowing.
Old 05-29-2014, 10:39 AM
kd6mlh kd6mlh is offline
kd6mlh is starting off with a positive reputation.
I found this in another forum as a reply to the same question.
I have a DRW 99 as well and installed the warn premium in mine this weekend. Tested them already in the mud and work great. The trick is you have to remove the wheel spacer. It is hour glass shaped so that you cant just slid them in but if you remove the spacer, install them and then put the spacer back on over them it WILL fit. It turned a 15 min job into a 45 min job but it is super easy
And what did you come up with on this?
I have a 2001 DRW and will be doing this shortly as I have the warn hub setting on the bench.
4 WD locking hub broke, need help.. mark227 1999 to 2016 Super Duty 12 12-20-2015 07:17 PM
warn 4x4 hubs drewdole Offroad & 4x4 4 01-29-2015 10:39 AM
manual hubs GRADY44 1999 to 2016 Super Duty 1 10-15-2014 07:42 PM
Front axle hubs - SRW vs DRW Sparky83 Offroad & 4x4 4 02-14-2014 05:56 PM
Early '99 F350 front axle rebuild. ckseppa 1999 to 2016 Super Duty 0 04-21-2012 05:01 PM
Tags
350, 450, 99, dually, duallywarn, duty, f350, hub, hubs, lock, locking, lockout, plier, super, warn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
