1990 E250 manuals - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
1990 E250 manuals
Old 02-04-2012, 08:01 PM
cityjack cityjack is offline
cityjack is starting off with a positive reputation.
1990 E250 manuals
Evening all,
I just bought a 1990 E250 cargo van with a 302. I usually just go right out and buy a Haynes but happen to swing by the local library and they had a Chiltons for the year and model I just bought. The book was horrible. I'm having second thoughts on getting a Haynes now. I was most specifically looking for a chassis schematic that would have in detail the fuel pump, selector switch, and the valve that controls the fuel from both tanks to the engine. My dual tank system is not working and the previous owner was having to live off of the rear tank only. I was told not to touch the switch or I'd run out of gas. I want to learn more about the system but the Chiltons was of no help at all. Before I start to troubleshoot the system I need to know where all of the parts are and how they are wired. Can anyone recommend a manual or where to get a cd or something that will have my van in detail please.
Thanks and have a nice night.
Sid
Old 02-04-2012, 08:15 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Isn't much to these selector valves. Often they quit working cause they're to dirty to work.
Removing, and cleaning it might get it working again, or the fuse for it is burned.
Heres what it looks like, yours might be slightly different, as this one is on my 1985 E350 Diesel van.
Personally, I wouldn't bother with it, if the rear tank works, just use that one.
Old 02-04-2012, 09:13 PM
Selector valve
Thank you sir for the pic. I appreciate the advice on just sticking with the rear tank, but we plan on doing some long hauling with this van and would really like for both tanks to be operational. Any idea where I can get a good manual for my van or a cd of such?
Thanks once again sir.
Sid
Old 02-04-2012, 09:28 PM
kb1jid kb1jid is offline
kb1jid is starting off with a positive reputation.
Check out E-bay for the manuals. You can get the ones that ford used Vol 1&2 also get the Electrical+ Vacuum Manual lots of info in them Also on your van you have a gas engine your valve will be different you have electric fuel pumps in each tank when you move the switch on the dash you turn on that pump and the valve on the frame switches by it self You could have a bad fuel pump in one of the tanks Make sure you get the Manuals for ECONOLINE, F- SERIES, BRONCO hope this helps
Old 02-05-2012, 08:26 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
Originally Posted by kb1jid View Post
Check out E-bay for the manuals. You can get the ones that ford used Vol 1&2 also get the Electrical+ Vacuum Manual lots of info in them. Make sure you get the Manuals for ECONOLINE, F- SERIES, BRONCO hope this helps
+1 on this ^^ I've found and purchased numerous OEM manuals for cheap money through FleaBay. They tend to be far far superior to any generic manual like Haynes, Chilton, Mitchell et al.
Best of luck with your problem.
Old 02-05-2012, 09:04 AM
Goin to ebay to shop
Thank you guys for the quick replies. I was over at ebay last night. I did purchase this manual. Look ok?
1990 Ford Econoline Club Wagon Electrical Vacuum Manual | eBay
Also there seems to be different color covers on the manuals on ebay, brown or green. Plus some sort of pre-delivery manual. Is 50 bucks a volume sound normal? I know its how bad do I want it, just don't want to jump the gun. If any of you all of the time today, you think maybe you guys can point the correct set out to me please. Thank you very much again and enjoy the game those of you who will watch. I'll be messing with the horses and playing with my new miller instead.
Have a great day all.
Sid
Old 02-05-2012, 09:36 AM
JWA's Avatar
JWA JWA is offline
The colors of the manual covers as displayed---assuming they're the same type---might be due bad photography so don't pay that much attention. There IS a difference though if its an EVTM, owners manual or full service volume. This is what you'd want to eventually have: 1990 Ford F150 F250 F350 Bronco Econoline Van shop service repair manual SET | eBay but that is crazy money--keep shopping!
Maybe create your own search in the manuals category for your year and truck type, perhaps allowing eBay to email notify you of new additions. If a good Buy It Now item comes up you'll be among the first to maybe ****** it up.
FWIW I found a nearly-unused two volume set in hard bound plastic note books, each over 5" tall----for like $40 shipped. Look for these two sellers: eBay My World - blackhatauction and: eBay My World - oharazmanualz
Contact them for your specific needs----they might not yet have listed it.
Old 02-05-2012, 10:27 AM
Manuals
Thanks a ton. You guys are invaluable.
Have a great afternoon.
Sid
Old 01-02-2015, 05:47 PM
johnperf johnperf is offline
johnperf is starting off with a positive reputation.
Smile 1990 e250 stalls after 20 mins
The problem was internal fuel pump in the gas tank. Very costly trial and error.
But problem went away immediately ....November 2014 , 130,000 K
Camper van with dul fuel tanks.
Repair Manual JackOHearts 1999 to 2016 Super Duty 0 12-05-2016 08:38 PM
need cali emmisions help jonmorgan 1987 - 1996 F150 & Larger F-Series Trucks 6 09-28-2015 10:00 PM
Ignition Control Module Removal? VannerDude 1968-2013 Full Size Vans 13 02-14-2015 10:47 AM
Code 33 JoePeeper 1987 - 1996 F150 & Larger F-Series Trucks 4 07-11-2013 01:58 PM
Where is the fuel pump relay and inertia reset SANTA??? Todd F250 1987 - 1996 F150 & Larger F-Series Trucks 10 12-28-2002 02:00 AM
Tags
1990, 2001, 2004, 351, box, cleveland, diagram, disconnecting, e250, e350, ford, forum, fuel, fuse, pump, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
