diagnostic code P1891 - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 04-22-2003, 02:44 PM
expydriver expydriver is offline
expydriver is starting off with a positive reputation.
Hi All,
Having some trouble with my 99 XLT. For the longest time you couldn't switch it into 4wd, then one day last week - I tried it, it engaged, and now the light is still on even though the switch is off. The AWD works, so I hope I am correct in thinking it isn't a transfer case problem, maybe just an electronic problem. My husband is very mechanically inclined, and we had the diagnostic code read on it at a friend's transmission shop, but he is unfamiliar with the result of the reading. It came out as P1891 - Transfer Case Contact Plate Ground Return Open Circuit. Any ideas, or a shove in the right direction?
Thanks!
Martina
woodladyab
Old 04-22-2003, 02:56 PM
the4by4freek the4by4freek is offline
the4by4freek is starting off with a positive reputation.
Sounds to me like a bad transfer case motor. If you pull it off the rear of the transfer case and switch back and forth between 2 Hi and 4HI you should see it move. If not, you have a bad motor!
Old 04-22-2003, 05:39 PM
You think? I'll have hubby take a look tonight - it is booked to go to the Ford dealer on Thursday - but if we could fix it ourselves, boy - would that be a lifesaver (and a $$$ saver!)
If anyone has any other suggestions - please throw them out there..............Thanks!
Old 04-23-2003, 12:59 PM
ktmguy70 ktmguy70 is offline
ktmguy70 is starting off with a positive reputation.
Do the motors seem to fail more on the ones that DONT use 4x4 very often,, Kind alike they freeze up from non use like the old Airconditioner compressors used to YEARS ago before they started tying them into defrost etc..
Just wondering what peoples thoughts are on this
Ron
99 XLT 4.6
Old 04-23-2003, 03:18 PM
Hmmm, I wonder now - because in the life of this vehicle - it has been switched over into 4hi from a4wd maybe 10 times, tops... Curious now...
Old 04-23-2003, 03:24 PM
Will Post A new thread Regarding such
Old 04-24-2003, 11:30 AM
We (think) we found the problem - we just have to wait a few days for the part to come in... It looks like it is the relay/solenoid (not sure of the name) that sits near the radio under the dash. The dealer is not even sure of the name of this part... Will let you know when we find out in case someone else has the same trouble. He looked at the transfer case motor, no problems there it seems.
Thanks!
explore sam88 Explorer, Sport Trac, Mountaineer & Aviator 1 05-21-2014 08:01 AM
what i can do? sam88 Clutch, Transmission, Differential, Axle & Transfer Case 0 05-20-2014 08:45 PM
06 F 150 sof 4x4 wont engauge papajoe8 2004 - 2008 F150 3 07-06-2011 07:36 PM
Help! many codes where do I start? xlsportrider Electrical Systems/Wiring 6 06-13-2011 10:17 AM
T-case WOAS...Nine Codes!... gvrangr98 Ranger & B-Series 5 02-15-2009 08:48 PM
Tags
1891, 2003, 4x4, 97, case, code, contact, expedition, f150, ford, p1891, plate, transfer, troble, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
