Headlights and HID's
#61
I think the photos show, when the proper unit is properly installed into an OEM style housing, the beam has the same characteristics as a stock incandescent bulb and is perfectly safe for use.
You don't have to buy lens based projector beam housings, but if you do, you'll need to shell out decent cash to get the ones properly designed NOT to blind other drivers. That is what seems to be the chief complaint for those that think HID bulbs alone are the culprit...in reality most of those blinding drivers are because of cheap projector beam housings, the wrong HID bulb being used, the reflectors not being aimed right or a combination of the three.
The point of my post is to show the claim that "you can't use HIDs in anything but a projector housing or you will blind other drivers" is patently false...these photos prove that once and for all.
As with anything, buy cheap or generic/incorrect parts and you take your chances. Buy the correct parts, buy decent quality and install them properly and you should be fine.
#62
I get so sick of people whining about other people using HID's. You are not going to blind people, they work great. You don't need projector housings, or anything else special. They work great in the factory housings. They don't have a terrible light pattern. Having put them in stock housing and seen before and after I do know. I bet most here regurgitating the same old crap have not even seen HID installed in our trucks.
If that bothers you then don't get them and stick with your dimmer factory spec bulbs, keep sucking the baby bottle, and well you get the idea... To some the earth will always be flat.
Flame away sissys!!!!
Any reviews on 6" exhaust tips?
#63
#64
I dunno what your definition of safe is but they are illegal, if that matters to anyone. I owned a pair of the last DOT approved aftermarket HID lights made by mcculloch, but DOT eventually pulled their approval of all aftermarket HID's.
Here is a good link off hella's website that breaks it down:
http://www.hella.com/produktion/Hell...d_Approved.jsp
Here is more info straight from the horse's mouth (NHTSA is the part of DOT responsible for certifying what equipment is legal for use on your vehicle):
Update: May 3, 2007:
NHTSA Cracks Down on Aftermarket HID Conversion Kits
The National Highway Traffic Safety Administration (NHTSA) is targeting high-intensity discharge (HID) conversion kits for enforcement actions. NHTSA has concluded that it is impossible to produce HID conversion kits (converting a halogen system to HID) that would be compliant with the federal lighting standard, Federal Motor Vehicle Safety Standard (FMVSS) No. 108. The noncompliant kits frequently include a HID bulb, a ballast, an igniter, a relay and wiring harness adapters. The NHTSA believes this equipment presents a safety risk to the public since the kits can be expected to produce excessive glare to oncoming motorists. In one investigation, the NHTSA found that an HID conversion headlamp exceeded the maximum allowable candlepower by over 800%.
Under FMVSS No. 108 Section S7.7 (replaceable light sources), each replaceable light source for headlamps must be designed to conform to the dimensions and electrical specifications for the headlamp source it is intended to replace. For example, if an HID kit is marketed as replacing an H1 light source, then it must match the H1's wire coil filament size and location, the electrical connector size and location and the ballast design for use with an H1 light source (which is impossible since there is no ballast). Consequently, companies that are manufacturing HID light sources (e.g., D1S, D1R, D2S, D2R, 9500, etc�) with incandescent light source bases (e.g., H1, H3, H7, H8, H9, H11, H13, HB1, HB2, HB3, HB4, HB5, etc�) should be aware that this light source design would not be one that conforms to FMVSS No. 108, and could not be imported and sold in the United States without violating Federal law. (The importer is treated as the manufacturer and subject to the same fines and penalties that apply to a domestic manufacturer.)
NHTSA has also determined that a commonly used disclaimer "for off-road use only" has no legal meaning and is not recognized by the agency as the manufacturer, importer and retailer are not in a position to control use once a product has been sold. Any equipment offered for sale which is covered by FMVSS No. 108 (headlamps, taillamps, side markers, etc.) must comply with the standard.
#65
#66
So, you guys have any suggestions on a quality HID kit? I've dealt with the cheap crap and not going there again. A few I saved in my bookmarks a while ago where:
HID Kits - Xenon HID - H.I.D Lights - Philips HID Kits Store
Philips Xenon HID Lights Bulbs Ballasts Kits
HID Projector Headlight Retrofit for Subaru, Honda, BMW, Scion and More | LightWerkz.net
#67
#68
Now, if you live in an inspection state...well...good luck during inspection time!
As a side note...being raised in PA but living in CA, I can't BELIEVE California hasn't instituted some kind of annual inspection process. They regulate every other thing you can think of short of breathing, yet you can do almost anything to your car outside of emissions alterations and no-one questions you. I've seen some RIDICULOUS cars on the freeway that wouldn't pass the "say it out loud" test in other states.
#69
Not sure what you mean by inspection state, But in Pa you have your vehicle's inspected very year. I do agree with you Robert, "MYTH" busted! My findings on HID's In factory headlights Should not BLIND on coming cars "IF".. the headlight is adjusted proprely. The HID bulbs that I purchased and installed in my headlights throw the light in the same pattern as the oem type bulb in the same headlight. Just a more intense, clearer light... HID: High-Intensity Discharge.
#70
I started this thread to show everyone what I did headlight wise to my excursion. If they were thinking of getting the 05 look-a-like headlights that didn't need cutting to install, Here's a pic of what they look like installed. The same for 05 conversion and HID's. I like HID's as well do many others. Some do not like them and I can respect that. If you all want to have a debate on HID's Good, Bad or whatever. How about one of you START a separate thread on that...
#71
#72
#73
#75
Now if you live in a state that doesn't require annual inspections - CA for example - you could potentially run those indefinitely without issue IF you run them as in the photos (good bulbs, good reflectors, adjusted properly).
