6.0 fan Clutch - Ford Truck Enthusiasts Forums
6.0 fan Clutch
Old 02-04-2012, 05:27 PM
dr103 dr103 is offline
dr103 is starting off with a positive reputation.
6.0 fan Clutch
It seems as though my fan clutch is not working. I put in the fss for the sc2. Fan speed runs from 325 to 650. My temps are running 188-192 just regular driving. When pulling heavy loads, temps may run up to 202. I know it's cooler but I think the fan should be coming on more especially when pulling heavy loads. My heavy loads are round 26-28000 lbs. I have not seen the ect above 202. EOT temps are rite where they need to be.
Any of you pros know of any trick I can do to test short of taking it to dealer. Out of warranty on time but short on miles.
Thanks David
Old 02-04-2012, 05:37 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Sounds like its working ok to me
202 ECT isnt that Hot
at 190ECT the thermostat just begins to open and is not fulley open untill around 218* ECT
You wont see any big fan increase untill 216-218 ECT at that point mine Fan will Kick upto 1500-1800 Fan RPMs
Also lots of things play into the Fan Speed like Ambeint temp,ECT,Speed,A/C on stuff like that
I think your Fan is Just fine IMO
Old 02-04-2012, 06:26 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
active command fanvar# fanss should be aprox 2800 rpm with engine at 2500 rpm.
Old 02-05-2012, 07:08 PM
Bismic In laymen terms what are you saying. I understand the 2800 @ 2500. Didn't understand the first part.
David
Old 02-05-2012, 07:18 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
I didn't see a Bismic answer. Are you looking for his op over cheezit? They are both very knowledgable but cheezit is a diesel tech. Just trying to clarify.
Old 02-05-2012, 07:24 PM
cheezit's Avatar
you need a scan tool that do active commands such as AE or ids. go to the active commandf function and get pids fanss fanvar# and rpm
then do as suggested.
Old 02-05-2012, 08:21 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
dr103 you need to correct your post ASAP - don't want cheezit to quit the forum!! (Can't hold a candle to him!! I can barely even handle his tuned truck - hard to keep the rear wheels straight - lol).
Old 02-05-2012, 08:22 PM
cheezit's Avatar
thanks Mark.
Its the one thing in life I have found myself to be good at.
Old 02-05-2012, 08:45 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Wonder if he has the EGR valve unplugged?
Old 02-05-2012, 11:13 PM
My fault cheezit. Had just read an opinion by Bismic & he was on my brain. Again Sorry. No egr is still plugged in.
David
Old 02-06-2012, 07:28 AM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
Quote:
Originally Posted by cheezit View Post
thanks Mark.
Damn that's funny...
Old 02-09-2012, 04:00 PM
6.0 fan clutch
Did a good test today I think. Had a job where I had to drive about 1.5 hours to get to with my skid steer & hydro ax.It was a little warmer today so that was good. While pulling 28000 lbs I'm noticing the fan speed & ECT. When ECT gets to 206 the fan will begin to speed up. By 209-210, the fan speed will increase to 18-2100 rpm. It does cool down, but I never here the fan. I have always been able to hear it. I'm just wondering if the fan is slipping being it never goes over 2100. The engine was at 2900 rpm with the fan at 1900-2100. I am using a ScanGauge 2 for all my monitoring.
Just wondering what you pros think is going on.
Thanks David
Old 02-09-2012, 07:15 PM
cheezit's Avatar
what was fanvar# when that was happing. thats the only way to know.
Cooling the tranny DDPJ 1994.5 - 1997 7.3L Power Stroke Diesel 23 04-20-2016 11:02 PM
6.0 Fan Feedback 88david 6.0L Power Stroke Diesel 1 04-13-2016 10:07 AM
Fan clutch operation while towing Chris56ford 1994.5 - 1997 7.3L Power Stroke Diesel 31 06-26-2014 08:06 AM
Fan Clutch question mlouritt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 04-19-2011 12:29 AM
Electric cooling fan vs Mechanical fan Flashman Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 06-25-2010 10:58 AM
Tags
06, 60, 60l, clutch, coming, f250, f350, fan, fit, ford, international, thread, truck, turns, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
