04 6.0 has no power after intake swap. Help please
Old 05-13-2011, 08:47 AM
jared427's Avatar
jared427
jared427 is offline
So I put an AFE intake on my truck and it ran like a four cylinder. So I pulled it off and put the stock one back on. My truck still seems really weak. Is there some kind of a computer reset I can do. I have tried disconnecting the batteries and that didn't help.
Old 05-13-2011, 09:59 AM
Zmann's Avatar
Zmann
Zmann is offline
what boost levels?
the only reset is unhook both batts
Old 05-13-2011, 10:18 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Before you disconnect the batteries again, drive it and see if it sets any codes. Sounds like you opened a can of worms in the wiring harness somewhere. Did you get the MAF sensor reinstalled and connected correctly? Also, being an 04 it could have an 03 or 04 motor. Can you give us the production date of the vehicle OR do you know where the ICP sensor is located--passenger side valve cover or under the turbo?
Old 05-13-2011, 12:45 PM
jared427's Avatar
jared427
jared427 is offline
The production date is 08/03 I believe its the early motor. I did unhook both batteries. Boost levels go up to 19psi but make very little power. The egt's get high too.
Old 05-13-2011, 02:40 PM
howell_jd's Avatar
howell_jd
howell_jd is offline
Perhaps you have a loose boot at one of the CAC (Charge Air Cooler) connections:
turbo to passenger-side CAC tube
passenger-side CAC tube to intercooler
intercooler to driver-side CAC tube
driver-side CAC tube to intake elbow
The boots crack sometimes. You could have inadvertantly separated a boot during the exchange of the intake (especially on the driver-side).
I too encourage checking for codes - a loose or cracked boot won't necessarily set a code though so make sure to check those boots!
Good luck.
Jonathan
Old 02-09-2012, 07:24 PM
awsmev's Avatar
awsmev
awsmev is offline
What was the outcome? i am having same issue
Old 02-09-2012, 07:30 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Any recent work?????
Have you scanned it for codes????
Old 02-09-2012, 07:35 PM
69cj's Avatar
69cj
69cj is offline
Bottom line, the 6.0 doesn't need an a/m intake unless you are making mega horse power. Leave well enough alone. If it ain't broke, don't fix it.
Viperfoxbat
10-04-2016 11:15 AM
RockinFord
03-28-2012 08:33 AM
ironhead86
01-13-2009 04:12 PM
workingdog
24
01-19-2007 05:25 PM
free90xlt
08-09-2004 09:54 AM
Quick Reply: 04 6.0 has no power after intake swap. Help please
