Fog Lamps Installation Questions
Hey y'all, picked up two pairs of lights that I'm gonna hang under the bumper of the truck ('94 F150XL)
Two questions since I can't go crawling around the truck right now...
1) Where would be the easiest place to run wires through the firewall?
2) I'd like to tap into something that's keyed into the ignition so the wires ain't always hot. The lamps are 55W a piece with a 15amp fuse for each pair. Is there someplace inside the cab I can grab the power from?
Sorry if these are simple questions that could probably be answered by digging through the truck. I'm always on the run with work, and don't get much free time. So I try to learn and plan things out in advance as best I can.
Thanks.
Thanks.
And I never did think of taping into that, that would make it easy. You are right, it is the brown wire. Already got a few new running lights tapped into that one.
Sorry for the stupid questions, but gotta learn somehow.
on
I bought a set of 10 bosch style relays from ebay, they came with connectors and about 12" of wire. I used 4 on each of my trucks for headlights and plowlights. They look like these, might be the exact ones I bought.
(5)12V BOSCH STYLE RELAYS 40A SPDT + (5) 5-WIRE SOCKETS | eBay
on
More on those ebay relays, the connecters lock to each other, side by side so if you are using more than 1 it makes for a neater looking install. The ones I got had 2 different gauge wires but they were in the wrong spots on the connecter, I had to remove them (easy with a small pick) and put them where they belong so the larger wires were on the terminals that went to Bat+ and headlights. They relays look to be of good quality and have lasted for about 2 years in the dump truck with no issues. I just installed them in the F250 a couple weeks ago.
I know my way around wires, how to splice crimp and solder. That's what kits teach. I've wired up simple things like a new stereo, speakers, CB radio, and I put fogs on my other car, but didn't use a relay. Forgive me, this is how I learn. I haven't had the truck that long, and all I need to know is how to best choose a relay for the lamps. Know what they do, never had to choose one myself though. Don't know many specifics about them.
on
MrMarquis,
you can do it yourself no problem.
first,understanding the basic relay;
think of it as a switch that is controlled on/off via a power wire.the main power comes from the battery,and you trigger it open/closed via the power source of your choice.be it a switch,or a power line that gets turned on when you turn the key etc.
this way,the relay handles all the load and simply passes it onto the light.
here is a diagram to show you how to do it.
simply copy the setup for your other set of lights.
i also bought a set of clear and yellow fog lights for my new bumper.
Automotive Wiring Tips
if you decide to skip the manual switch,then simply hook the brown wire onto pin #86.
perhaps you'll want the clear lights to come on with the running lights.that's what you'd do.
then perhaps you'd want to switch the yellow,then you'd put a switch between pin #86 and your brown line,or if want the second set to come on via the switch,even when running lights are off,then use either a direct battery connection (just don't forget to flip it off!) or use an ignition 12V from something.such as the radio power line (it's fine,it'll be used only for telling a relay to open.no real draw.) so that the key must be forward or back to turn them lights on.
lots of ways to mix it up for example.
I've got a question here please. I don't have any electrical experience (hate the stuff). I currently have lights installed on my truck (came with it when I bought it used) & was looking at putting a relay on for them. I have a 5 wire relay setup I used before on a '94 Dodge I had. Someone else installed it for me. Do you have a picture (like the 4 wire setup posted) on how to hook it up? Thanks!! I want mine to be able to turn on any time (not keyed). Have had them connected to the switches I have in the dash several times by the Tech School where I used to live. Last time they worked about 2 - 3 days & quit again. Looking at it, I think the wires have come off the switches, so I'll need to figure out how to reconnect them when the weather gets warm & I can get out there to play with it some.
on
The 5 wire relay is hooked up the same, you don't use the center terminal.
on
NO NEED TO YELL.
