2011 steering popping noise - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-04-2012, 04:04 PM
RAPR's Avatar
RAPR RAPR is offline
RAPR is starting off with a positive reputation.
I have a 2011 F250 4x4 with 8000 miles. I put a 3.5" ReadyLift on it at 3500miles and Rancho dual stabilizers at 5000miles. This past week I've started to noticed my truck's steering making slight popping noises when turning the steering wheel. I crawled under the truck today and I can't pin point the orgin of the noise. It seems it is coming from higher up in the steering system possibly. Does anyone have any suggestions or experience this before? It doesn't seem to be from the wheels or tie rod.
Old 02-04-2012, 06:19 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
My guess would be ball joints.
Old 02-04-2012, 07:02 PM
RAPR's Avatar
But the noise isn't coming from anywhere near the wheels and the truck only has 8000 miles on it
Old 02-05-2012, 03:37 PM
RAPR's Avatar
I've been doing some research and came across this mechanic guide that targets a condition similar to my symptoms.
2008 2011 Ford F Super Duty Clunk/ Pop Noise Heard/ Felt Under Floor Pan While Turning | Motobild | Auto Repair
Has anyone ever heard of this before?
Old 02-05-2012, 04:02 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
pitman arm tight ???
im going to assume you changed it with the lift..
Old 02-05-2012, 07:10 PM
RAPR's Avatar
The Lift Kit included 3.5" powdercoated steel coil spring spacers, sound isolators, shock extensions,*sway bar*frame mount spacers, bump stop extensions, carrier bearing spacer, track bar relocation bracket, radius arm drop brackets*and OEM-style 5.0" Rear Lift Blocks. I got the lift installed by a local shop....and they did a 500 miles inspection at 4000miles and said everything was still tight. I'm out of town on business, so I'll try to bring it back by sometime this coming week.
Old 02-05-2012, 09:45 PM
RAPR's Avatar
I just took my truck on a 45 mile drive making the same turns into neiborhoods and parking lots that have been making the truck produce popping noises....and I heard and felt nothing. The inconsistency makes this case that much more confusing.
Old 02-07-2012, 12:50 AM
hmmm your pitman arm might be complaining about angles..
3.5" lift with a stock pitman arm is gunna cause weird angles for rod ends to deal with.
are you sure there was no pitman arm in the kit ?
Old 02-07-2012, 08:50 AM
beached350 beached350 is offline
beached350 is starting off with a positive reputation.
Same feeling in steering wheel of my 2010 f350 4x4 screw, srw, short bed...stock suspension....
Old 02-07-2012, 12:45 PM
RAPR's Avatar
The website for the lift and its compoents:ReadyLift 2011-UP Ford Super Duty 3.5" SST Lift Kit Stage 4
I talked to a tech guy at ReadyLift and he said not to add a pitman drop arm. He said it would throw off the geometry using their lift.
Old 02-07-2012, 05:43 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
I haven't looked at it on this truck but I had a similar problem on a few trucks I worked on long ago. I know your truck is newer, but it sound similar to a steering knuckle that is bound up. The knuckle moves ok one way but not the other. Gives you a popping type feel in the steering wheel and if it's really tight you can sometimes hear it as the wheel is turned outside the truck.
Old 02-07-2012, 07:04 PM
RAPR's Avatar
Quote:
Actually I don't feel it in the steering wheel at all. I feel in through my feet along the floor pan and I can hear it. I did have plans to bring it back by the shop that installed the lift (if thats even causing the problem) but since the popping noise stopped as of 2/5/12, they won't really be able to diagnose much. They told me to wait for it to start making the noise again and bring it by the shop so they can try and diagnose. Its really hard to diagnose a problem, when the symptoms aren't even consistent!
Talking with ReadyLift, they said that the only thing they could see being a problem is if the traction bar relocation bracket wasn't torqued to the 406 ft-lb requirement....which they said took an industrial tool most shops don't have. They said if it was loose, it could allow the traction bar to slide and cause geometry problems. When I called the installer, they said they did in fact have the industrial torque wrench required to apply the required torque. My head is spinning over this right about now.
In case a picture helps, here's a picture of my steering assembly:
Old 06-07-2012, 03:17 PM
WinterRoad WinterRoad is offline
WinterRoad is starting off with a positive reputation.
My 2011 F-250 CCLB 6.2 4x4 does the exact same thing. Suspension is stock, same type of noise/feeling... seems to be more common when I have a trailer hooked up. Both bumper pull and fifth wheel trailers have made this "noise". Happens rarely and I cannot re-create for the dealer. I will watch this thread with hopes for a solution!
Old 06-07-2012, 05:01 PM
RAPR's Avatar
I haven't heard of anyone else having the problem besides me. For the past few months I've only been noticing it when its wet/raining. I don't notice it at any other time now, even when towing.
Old 01-26-2013, 03:14 PM
kirkhammer's Avatar
kirkhammer kirkhammer is offline
kirkhammer is starting off with a positive reputation.
Did your dealer ever figure out what exactly was causing this?
My 12 F-350 with 4.5" lift and 13,000mi has started to do this too. Its raining too today so its a really loud clank or pop when my streering wheel goes from lock to lock. To me it sounds like its coming from the gear box itself.
Popping noise from rear of truck Josh Richter 2017 Super Duty 12 01-23-2017 07:09 AM
Rotation Noise F350Man79 1999 to 2016 Super Duty 8 03-31-2016 05:14 PM
Crunch-Pop-Thump Noise from Steering Gear Box? golfnut324 1994.5 - 1997 7.3L Power Stroke Diesel 5 01-13-2016 12:37 PM
Popping & clicking noise in front end jeepfix 1997-2006 Expedition & Navigator 6 08-22-2015 10:18 AM
Thump feeling in steering wheel 97ExpGuy 1997-2006 Expedition & Navigator 7 10-25-2013 01:54 PM
Tags
2011, chrome, edge, escape, f150, f250, f350, ford, makes, noise, poping, popping, steering, truck, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
