Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-04-2012, 02:16 PM
56 ford custom's Avatar
56 ford custom 56 ford custom is offline
Garage is empty, add now
56 ford custom is starting off with a positive reputation.
1960 f100 292/fordo with trans cooler with lines into block of motor? What to do?
Ok I have a 1960 f100 with a 292 y block and ford o matic trans. I pulled the old motor out because it was on its last leg. Well the old trans has a cooler on the side of it and hard lines that go into the block of the motor where the water jackets are. The new trans I am pretty sure its air cooled. Which one to go with?
  #2 (permalink)
Old 02-04-2012, 06:20 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
I'd go with the air cooled.
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 02-04-2012, 06:29 PM
Drewmeister Drewmeister is offline
Drewmeister is starting off with a positive reputation.
Quote:
Hello - this is funny because I had the same thing on my '67 when I pulled the tranny years and years ago. It had cooler lines routing coolant back to a box thing on the side of the tranny. I'd never seen anything like that.
I chose to plug the holes in the block and run the tranny fluid up to a B&M cooler in front of the radiator. I ran hard lines I pulled from a truck at the boneyard. It worked just fine.
Hope that helps.
  #4 (permalink)
Old 02-05-2012, 02:43 AM
trans
Hope that helps.
Can you please post some pics?
  #5 (permalink)
Old 02-06-2012, 11:54 AM
Can somebody post a pic of that conversion?
  #6 (permalink)
Old 02-06-2012, 01:08 PM
lance65's Avatar
lance65 lance65 is offline
lance65 is starting off with a positive reputation.
pm sent.....................
  #7 (permalink)
Old 02-06-2012, 01:10 PM
lance65's Avatar
an aftermarket cooler will have two lines,one in one out.Most come with a mounting kit to mount it to your radiator.Hook up the tranny lines to it with oil cooler hose and mount it.done.
  #8 (permalink)
Old 02-06-2012, 02:09 PM
The thing is that these libes arent tranny fluid its water. Does anyone here have a diagram for this or even a part number,brand or place I can get it? Anyone here done this before and have pics?
  #9 (permalink)
Old 02-06-2012, 05:38 PM
Sorry, I made the change 15 years ago. I don't have any pix.
  #10 (permalink)
Old 02-06-2012, 05:41 PM
Okay, now I'm caught up with the thread. Apologies for the double post.
What I'm talking about is changing the system from one that brings coolant back to the transmission to one that is more conventional and brings tranny fluid up to an external cooler or, more commonly, the radiator like you would see on a truck from the '70s for instance.
Is this what you want to do or would you rather keep the factory system that routes coolant back to the tranny?
  #11 (permalink)
Old 02-06-2012, 05:52 PM
I mean I would like to keep most of it original but I want it to cool well too. Is the original cooling that bad?
  #12 (permalink)
Old 02-06-2012, 06:42 PM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
tbirdscott is starting off with a positive reputation.
Vehicles have used water to oil tranny coolers for decades with no trouble. Why do you want to get rid of it so bad?
Scott
__________________
1960 Comet mostly stock, summer DD
1979 Ranchero/Thunderbird 'Thunchero' 390 or 460 powered in the future...
1980-82 thunderbirds everywhere you look
1994 F350 IDI turbo getting a 1959 Mercury body transplant
1994.5 F250 PSD, 5spd 4" rancho on 35's
  #13 (permalink)
Old 02-07-2012, 12:49 AM
Quote:
Scott
I wasnt trying to get rid of it, just trying to figure out which would be the best for what I want and need the truck for.
  #14 (permalink)
Old 02-07-2012, 01:32 AM
tbirdscott's Avatar
For just normal use I would say stick with the OE cooler. Add a temp sensor to monitor it if you are concerned or plan on towing/hauling regularly.
Scott
__________________
  #15 (permalink)
Old 02-07-2012, 09:38 AM
Scott
How would I go about installing a temp sensor? I wount be towing or hauling at all. If I were to install a trans cooler on it how would I go about doing that without changing my radiator? I am mmost likey sticking with stock just checking my options.
Tags
1960, 1960f100292, 292, cooler, engine, f100, ford, hickaneese, matic, trans, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
