You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Just picked up a new starter drive for my 60 F100 and notice that it will not work it seems to be longer than the one I took off.Is ther a replacement starter drive for the shorter shaft starter that I have? or am I just not seeing it correctly? Thanks Mark
OK I bought a BWD starter drive it calls for a SD553P well when looking around I found a SD595P that looks just like the one I took off...I feel thier is 2 different sizes one for the longer shaft starter and one for a short shaft starter...Keep you posted when iot come in Mark
1961/64 is not the same, because Ford changed the starters in 1961.
------------------------------------------------------------------- B6C-11350-A .. Bendix 'inertia' Starter Drive.
Applications: 1954/64 F100/250 223 (A/T).
These Bendix drives are about 5" long when wound, are retained on the shaft of the armature by a roll pin.
The roll pin is hidden by the large coil spring. So, the spring has to be unwound to R&R the drive.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
