Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 02-04-2012, 09:18 AM
penguinshockey penguinshockey is offline
Garage is empty, add now
penguinshockey is starting off with a positive reputation.
Rebuild or Replace Engine in 1997 F-150 4.6 V8
The engine in my 1997 F-150 (4.6 V8) began running really rough and died while driving on the interstate the other day. It would not turn over however the starter sounded like it was engaging. The shop looked at it and said it was frozen with no oil. I asked them if they could tell where the oil leaked from since I had just checked it 2 weeks earlier. They are looking into options and I haven't heard back from them yet. The vehicle has around 130000 miles on it. I realize it may be a premature question but I was wondering if there was any hope of trying to rebuild the engine - given what I now at this point. Given the truck is 15 years old I don't wasnt to sink a ton into it. It is a spare vehicle and I have the time to work on it, either rebuilding the engine or replacing it with a used long block or reman engine. Any thoughts, opinions, or advice would be greatly appreciated. Thanks!
Penguinshockey
2004 F-150 SCrew 5.4L
2008 F-150 SCrew 5.4L
1997 F-150 SCab 4.6L
  #2 (permalink)
Old 02-04-2012, 09:34 AM
92nite351's Avatar
92nite351 92nite351 is offline
1992 Ford F-150
92nite351 is starting off with a positive reputation.
i think a reman is the quickest, cheapest way to go.. rebuild might include a lot of machining an that gets pricey.. do some good research
__________________
Eric
1999 f150 Supercab 4x4
5.4L Auto 3:73 LS
Off Road package
  #3 (permalink)
Old 02-10-2012, 02:46 AM
ford4554's Avatar
ford4554 ford4554 is offline
ford4554 is starting off with a positive reputation.
Pick up a crate motor and swap it out.
  #4 (permalink)
Old 02-10-2012, 08:11 PM
fordiesel69 fordiesel69 is offline
fordiesel69 is starting off with a positive reputation.
If it is a 4x4, find a junkyard motor and install it. Chances are it will be good, if they give a slight 30/60 day warranty.
If a 4x2, part out the truck and find another.
Look at the vin#, if you have a romeo, a crown vic / grand marquis/ town car engine will fit. If windsor, then you will need to stick with a truck motor.
__________________
My Rigs:
04' F-150 Heritage, 4.6L V8, Ext Cab, 4x4, 3.55 LS.
86' F-250 XLT Lariat,6.9 Diesel, Ext Cab, 4x4, 4.10's, 8'bed, Push Button Glowplugs, etc...
99' Crown Vic Police Interceptor (P71) w/Steet apperance package
Tags
1997, 46, 97, engine, f150, hard, installed, motor, rebuild, rebuilding, replace, swap, truck, v8, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
