1956 Moving rear leaf springs to the inside
Hi guys.....
I am about to move my rear leafs to the inside of the frame, and I need to know if there are any tricks to doing it, and/or anything I need to look out for. Also, when you DO move them, is there any stability issues afterwords? Thanks in advance......
box the inner frame rails , and swap the hangers from left side to right side . i had a 55 on a shall we say teaked 74 1/2 ton frame . it had a cut down long bed and 1/2 ton fenders , and with them moved inside you had room for if i remember right { assuming the right offset wheels } 14 inches of rubber under it with a set of mini tubs . never got it finished though ........
I would strongly recommend an anti sway bar for this setup.
(it will require bolts into the chassis too)
Sam
but I thought u said u already boxed the frame..
if u attempt to put them on the inside without boxing that area you lose a lot of the support the springs need..
Sam
if u mean you want to move them FURTHER inside.. the yes, you'll have to make some additional mounting supports..
I don't know how much more inside u can go tho, before u end up with an unstable situation..
Sam
Lot of discussion on how...my question is why? To answer one of your original questions, yes there will be stability issues. Anytime you move a mounting, like a set of leaf springs, closer together you are increasing the lever arm for the applied force coming from the wheels. If you are planning on building some sort of "pro street" machine then I would go the same route that they do...4-bar with coils. And as Sam mentioned, you are going to need a beefy anti-sway bar setup.
ike55
01-06-2012 09:13 AM
