Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 02-04-2012, 01:51 AM
Ohiocrewcab's Avatar
Ohiocrewcab Ohiocrewcab is offline
1975 Ford F-350
Ohiocrewcab is gaining momentum as a positive member of FTE.
Cam hunting
Ok I'm working on my 360. I want to replace the cam and don't know which one to get.
The components I have are:
-stock heads
-performer 390 intake
-long tube headers
-600cfm vac. Sec. Holley
What I'm using the truck for is purely towing its a 75 crew cab 8ft bed 2wd. It ain't no hot rod nor will it be. With a T-18 and 4.10 gears I was thinking about running the Crower beast cam with the rpm range of 1200-5200. I doubt the truck will see the 5200rpm but don't know. I will do springs and lifters at the same time. Any better cam choice? I also understand that most chose their cam for the reason they did. What is gonna work best for my application?
  #2 (permalink)
Old 02-05-2012, 07:17 AM
mustang_gt_350 mustang_gt_350 is offline
Garage is empty, add now
mustang_gt_350 is starting off with a positive reputation.
Camshaft selection has a major part to do with compression. And since the lower compression of the 360 will limit you to what cam you should run. You can go larger but you won't have the compression to get the most out of that grind. Check to see what CR is recommended for the cam you are looking at.
__________________
late 99 reg cab 4x4 4r100
www.DIY-injectors.com
Idm info (updated 3/17/08)
http://www.shol.com/shadow_tech/idmmod
  #3 (permalink)
Old 02-05-2012, 02:18 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
1968 Ford F-100
MIKES 68 F100 is starting off with a positive reputation.
checkout camquest it's software by comp cams .
they have a free version , you have to register but no problems there .
but you can flip between different cams and see what hp and trq you get . it's great for deciding what grind you want , only problem is you only can choose between comp cam brand cams , but you can simply pick a cam from another manufacturer with similar numbers
link
CamQuest ? Select The Perfect Camshaft & Valve Train Components
__________________
67 390
10:1 C/R
Lunati 62001 cam kit
home ported heads/Flotech headers
Edelbrock performer intake /Holley 750
  #4 (permalink)
Old 02-07-2012, 08:51 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
1976 Ford F-250
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
I would say something like the Comp XE256H, Lunati 62000, or maybe have one custom ground for your app. I haven't used them but Oregon cams is highly recommended by the members of the "other" FE forum for custom grinds. The owner Ken is very FE savvy.
__________________
Jeremy
1976 F250 4x4 Ranger XLT. 445FE, NP435/205, D44/60 4.10
AKA the never ending project.
  #5 (permalink)
Old 02-08-2012, 08:30 AM
1975 Ford F-350
ok so i checked out the camquest link and well..... it wasnt very helpfull at first but i didnt have alot of time to mess with it. the Comp XE cams look good but nothing is said about compression ratio. so im starting to lean towards the Comp more than the Crower cam now.
  #6 (permalink)
Old 02-08-2012, 09:09 AM
HOTWRENCH HOTWRENCH is offline
HOTWRENCH is gaining momentum as a positive member of FTE.
Talking CAMS
Here's a few cams I have used , the first one makes great torque down low and super mid range. Elgin E966P int lift .486 -- exh lift .512 -- duration at .050 int 204 exh 214 . The next one is a SUMMIT brand .533/.533 lift
int 216 / exh 216 . this one is a bit more agressive but very streetable good torque and power. As far as a cam for towing the Elgin would work well with your setup, Competition products has great prices on these and other cams. I have used Comp Cams 268H in 390's but may be more than what you want to tow with.
Just Some Thoughts ----- Hotwrench
__________________
FERGUSON'S GARAGE est. 1967
car , truck , heavy equiptment repairs
4 X 4 specialists PORTABLE WELDING SERVICE
TOWING New @ used PARTS
1981 L 800 460 5 speed , 2 speed rear
1957 F 600 390 5 speed
Tags
1973, 360, 390, 62001, big, cam, choice, compression, enthusiasts, explorer, fe, ford, hunting, low, lunati, towing, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
