No heat at idle - Ford Truck Enthusiasts Forums
No heat at idle
Old 02-03-2012, 10:44 PM
the shop the shop is offline
the shop is starting off with a positive reputation.
No heat at idle
Working on my wife's 2003 Excursion with a 6.0L Power Stroke Diesel
No heat, replaced the heater core,water pump, thermostat we have heat driving down the road but not at idle,Checked the blend door and it opens and closes ,the door is not cracked and the motor appears to be operating normally
The heater core is hot above an idle is so hot you can't touch it, but at a idle its cold. any ideas out there ,Thanks
Old 02-04-2012, 01:47 AM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
Alot of no heat at idle problems stem from failed head gaskets. You could check the in-line heater valve near the alternator to make sure its opening and flowing coolant.
Old 02-04-2012, 04:59 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
I'm having the same problem with an '04 extended cab. Truck runs like a top with 240,000 miles, just no heat at idle. Mine doesn't have a heater control valve.
Old 02-04-2012, 07:29 AM
dee004's Avatar
dee004 dee004 is offline
dee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant future
How long of an idle are we talking about here?
Old 02-04-2012, 07:49 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
There seem to be multiple threads recently with this issue and I think a further investigation is warranted.
Old 02-04-2012, 02:40 PM
sounds like the head gaskets
If you are driving down the road and the temp gauge is normal, the minute I let off the pedal the hot air goes to cold, I've heard back form Ford and they say the same thing about the head gasket leaking, so all get them on order Monday and all let you know the out come,Thanks
Old 02-04-2012, 02:41 PM
Old 02-04-2012, 02:42 PM
Quote:
The factory temp gauge is nothing but a cold/normal/hot gauge. Basically an idiot light with a needle. Are you blowing coolant out of the degas bottle?
Old 02-04-2012, 03:04 PM
hotrodpainter hotrodpainter is offline
hotrodpainter is starting off with a positive reputation.
I had this problem with my 6.0 and it was as simple as a low coolant level.
Old 02-04-2012, 04:42 PM
dee004's Avatar
Don't be ordering head gaskets just on that word. There are several issues which can cause what your explaining. May also be a warn water pump impellar. Do a coolant test to see if there is CO in the coolant and also do a pressure check of the cooling system. Blocktest Kits for CO are available online. See the following video and you don't need the EDAS installed.
HEAD GASKET TEST for 6.0 POWERSTROKE - YouTube
Old 02-04-2012, 04:56 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Quote:
I noticed that too lately
Quote:
This is one of the first things I would check
I just dont know about a bad headgasket causeing this can someone tell me why a Bad Headgasket would cause this. Does the extra pressure in the coolant system Disrupt the Coolant Flow to the Heater or something.
Usually when you have a Bad HGs you have Temp spikes and overheat conditions along with coolant puke.
so with that said shouldnt the heater Blow Extra Hot???
To me if you have heat out of the Heater while your going down the road and then have NO HEAT at Idel then you have a Coolant Flow Issue
be it a Bad Water Pump or say a Bad Cavitated Front Cover or maybe even a Low Coolant leval and maybe even a Bad Coolant Bottle CAP or even a Heater control valve thats stuck not opening all the way like it should I can see it being alot of other things besides a Head Gaskets Bad
Im just trying to wrap my head around the Fact a Bad HGs would cause no heat issues in the Cabin of the truck. so If anyone has a therory on this I would Love to hear it.
Old 02-08-2012, 08:51 AM
samiott's Avatar
samiott samiott is offline
samiott is starting off with a positive reputation.
I just had the same issue before I tore mine down, little or no heat at idle. I am wondering if you can hear any venting out of the degas bottle. I had a low pitched whistle on and off throttle from the degas bottle from the increased pressure that released through the cap. Just installed head gaskets and studs and the venting went away and now my heat will chap your face.. lol
I can only guess that bad head gaskets are related to the heat issue due to the coolant flow and pressure. dunno.
I'm sure someone with alot more experience than me could explain it.
Old 02-08-2012, 09:40 AM
dbenson dbenson is offline
dbenson is starting off with a positive reputation.
Same issue here... but my "problem" started after I did a lot of work including head gaskets, studs and EGR delete.
I'm curious... how many people with this problem have a functional EGR cooler still in place? I sort of figured that without the additional heat from the exhaust being dumped into the EGR cooler, the coolant might lose it's heat pretty fast at idle since these engine's don't really get hot at idle speeds. The only flaw in this theory is the abrupt changes in temperature while driving... if I go from driving under power to just coasting, I can feel the change in temperature from the cab heater.
So... to get some useful data... tell us about:
1. EGR or NO EGR?
2. Cold, Temperate, or Warm climate? (I call cold -20 celsius, temperate would be slightly above freezing, warm would be anything above 15 celsius)
Old 02-08-2012, 10:22 AM
prem1 prem1 is offline
prem1 is starting off with a positive reputation.
I lived with no heat at idle for a couple of years before I finally done the HG's, tried all the usual stuff but I was just in denial, t-stat, EGR delete, water pump, heater core, oil cooler. I never even really had any puking but upper rad hose would get fairly hard pretty quick so I always thought it was putting pressure in the cooling system.
Old 02-08-2012, 10:35 AM
samiott's Avatar
I deleted the EGR when I did the studs and gaskets. Heat works great without it. Heats up quickly and stays hot.
99 Expedition 5.4 no heat Buckland14 Modular V8 (4.6L, 5.4L) 1 11-10-2016 06:28 PM
Full time heat thru floor and vent, high rpm heat thru combination settings NTENSE 1999 - 2003 7.3L Power Stroke Diesel 5 10-26-2016 02:18 AM
98 Expedition Heat Issue HMAN1055 1997-2006 Expedition & Navigator 13 12-15-2014 11:44 AM
97 f-150: heater blows warm, not hot air. svenska57 1997 - 2003 F150 3 12-30-2010 09:43 PM
Do the 06 F150s have a heater control valve? eallanboggs 2004 - 2008 F150 4 12-13-2010 12:26 PM
Tags
03, 05, 2001, 2004, 60, cab, diesel, f150, f250, ford, heat, idle, ranger, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
