how would you guys do it? - Ford Truck Enthusiasts Forums
Old 02-03-2012, 11:02 PM
fordboy300 fordboy300 is offline
fordboy300 is starting off with a positive reputation.
(i also posted this same thread in the inline six section)
so i just took the block to the machine shop yesterday. so nows the time to clean up the engine bay a bit. so i have two options try and clean it with soap and water or getting some flat black spray paint!
my engine bay has what looks to be the rust proof stuff that comes from the factory or they do it as an up sale at the dealer.
see
please help!!!
Old 02-03-2012, 11:17 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Painting over dirt doesn't make for a real good paint job.
Old 02-03-2012, 11:29 PM
newrider3's Avatar
newrider3 newrider3 is offline
newrider3 is gaining momentum as a positive member of FTE.
All I see is oil/grease and dirt, not any coating you should be painting over. Get some simple green or purple power, a scrub brush, and a hose.
Old 02-03-2012, 11:33 PM
kedwinh's Avatar
kedwinh kedwinh is offline
kedwinh is gaining momentum as a positive member of FTE.
Same thoughts here. Got to clean it first anyway so see what it looks like after that, it just might surprise you.
Old 02-03-2012, 11:40 PM
true very true! now which one is a better degreaser?? simple green orrr purple power?? i should use a soft bristle brush correct?
Old 02-03-2012, 11:54 PM
ctubutis's Avatar
I used concrete driveway cleaner and a scrub brush (not necessarily soft).
Old 02-03-2012, 11:59 PM
TheKirbyMan's Avatar
TheKirbyMan TheKirbyMan is offline
TheKirbyMan has a good reputation on FTE.TheKirbyMan has a good reputation on FTE.
Mean Green works well too.
Old 02-04-2012, 12:15 AM
concrete drive cleaner??? where do you find that stuff
Old 02-04-2012, 12:25 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Quote:
Yes it does.....
Old 02-04-2012, 01:35 AM
My dad had a '73 Olds Cutlass Supreme years and years ago with an all white vinyl interior. It had sat in a barn and it had a bunch of mildew everywhere, and Mean Green took every bit of it off and left that interior looking like new. My dad thought at first glance it was just some cheap store brand stuff that wouldn't work very good...it was quite the opposite lol
Old 02-04-2012, 02:32 AM
bruno2's Avatar
bruno2 bruno2 is offline
bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.
Go at it with some soap and a scrub brush. Do that until the soap wont take anything else off. Then go get some laquer thinner and wipe it all down with that. You may be able to get a color that is close from the parts store and then paint it up.
Your truck looks exactly like mine did before I stripped it all down and painted it. Now mine looks better than it did from the factory.
Old 02-04-2012, 03:07 AM
6.9idiatsturbo 6.9idiatsturbo is offline
6.9idiatsturbo is starting off with a positive reputation.
a real good thing to use on it is oven cleaner comes in an aerosol can. breaks down the grease real good.
Old 02-04-2012, 08:15 AM
Dang guys these are all great ideas thanks a lot!
Old 02-04-2012, 09:36 AM
ctubutis's Avatar
Quote:
Walmart/hardware store/Home Depot
Old 02-04-2012, 12:03 PM
bruno2's Avatar
By the way, judging from the pic your Master Cylinder looks to be shot. I dont know if you had that on the list, but , you might want to put it on there if not.
Tags
degreaser, power, purple
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
