I figured it was a spindle, but can't find anything. Anyways, mine is trashed and the new spindle nuts obviously will not go one there, either way where the bearing sits is all chewed up anyhow. Any input is appreciated.
I need one like...NOW. It's definitely not a parts store item I guess. I don't want to have to crack into a whole bunch of trucks at the junkyard just to find they all look just as crappy.
The stealership will have one for about $350. Do you have a local 4x4 shop that deals with a lot of rear end stuff? If so you might call them. We have a couple places like that in Tulsa, Harmon 4x4 has a bunch of crap like that.
Is it just the lighting in that pic or is that spindle trashed all to hell?
See post #1
OP: Do you have any auto recyclers in your area (not junkyards). Auto recyclers do all the dismantling and usually have parts on their shelves, or they'll send someone out in the yard to pull off an oddball part. Saves you a ton of time and energy, and you don't need to lug tools around.
Well...its Arkansas so all there is are pick and pulls. I plan on hitting them hard tomorrow. It only takes me about 10 minutes to have a whole hub apart, and usually other people take the brake rotors so it makes it that much easier
