Using a Ford Quick Connect tool on fuel, A/C, etc. lines
See following video. Gist of it occurs at 1:52, and is the clearest video I've found of just how the tool does its job. Previous written descriptions I came across were a complete waste of time.
You posted this just in time for me.
I bought a used tank to put in my 93 F-250. Unfortunatly the plastic fuel line removal tools i bought to disconnect the lines, didn't work. Luckly the seller let me sawzall the lines to get the tank out of his truck.
I went to Oreillys to get that tool you demonstrate, but they didn't have it, I guess I'll try Autizone next.
I need to find the right tool so I can get the old lines off the new tank and my old tank, as well as change the fuel filters in both of my trucks.
__________________
92 F-150 flairside all stock 5.0 auto 2WD
93 F-250 4x4 flatbed 5.8 auto KnN, throttle body spacer, underdrive pulleys, flowmaster
73 Jeep CJ5 springover axles, reversed front shackles, 304, T-18, lockers front/rear, 4:29 gears, 33s
87 Toyota Tercel Tuner some engine mods exhaust
There are two different styles that are used- The first is the garter spring style shown there, the second is a finger spring style. It's a pain to deal with because the fingers fit in between the ends of the tools and then are not released. I have found that, if using the cheap tool, going with a size or two bigger than needed so the tool forms a complete ring works well.
__________________
Jared
Real trucks have the key on the left FTE Guidelines
