Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 02-03-2012, 01:13 PM
azcactus azcactus is offline
2000 Ford Excursion
My Garage
azcactus is starting off with a positive reputation.
intermittent brake shake
My 2000 v10 w/194K has developed an intermittent shake when braking. Severity from mild to severe. Had the problem earlier, suspected the rotors - replaced front rotors and pads with EB slotted rotors and Yellow Stuff pads. It was fine for a couple of months, now its back. Replaced the slide pins last night (they were in good shape, replaced anyway). Any ideas on where to look next?
  #2 (permalink)
Old 02-03-2012, 01:40 PM
hasteranger's Avatar
hasteranger hasteranger is offline
Garage is empty, add now
hasteranger is a name known to allhasteranger is a name known to allhasteranger is a name known to allhasteranger is a name known to allhasteranger is a name known to allhasteranger is a name known to all
Mine does this too.. I haven't changed anything yet, but its very intermittent... seems like its worst when I haven't used brakes for a while, like on cruise control on the interstate and I tap the brakes when someone pulls in front of me going down a hill.
__________________
'04 4wd Excursion Limited PSD, Go Rhino brushguard, Red Head Steering box, blue spring fpr, 3 pairs JL audio components.
78 4wd reg cab F150 Custom- factory air, '79 460 swapped in to stock C6, married NP205, 8' flatbed, 16.5x35x15" boggers, 6" superflex lift w/ skyjacker front coils, custom front bumper, trussed 9" rear with disc conversion, Mp3 input shaft stereo, Alpine v12 amp, Punch DVC 8" sub, 20' Zimmerman deckover
  #3 (permalink)
Old 02-03-2012, 02:04 PM
Sunline Fan's Avatar
Sunline Fan Sunline Fan is offline
Excursion Fleet Manager
2002 Ford Excursion
My Garage
Sunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputation
I'm going to guess that you have a caliper that's sticking, or your wheels are torqued too tight on a couple lug nuts, causing an imbalance.
__________________
Jon
2005 Excursion Limited 4x4 V10, C1, TK/NH, 3/17/05, RedHead, Blackwood wheel, Rancho 9000XL, Air Lift, 61k
2002 Excursion Limited 4x4 PSD, 3/5/02, 150k, for parts & diesel swap
2007 Sunline Solaris T-286SR travel trailer, 3/8/06, 6691.8
  #4 (permalink)
Old 02-03-2012, 02:14 PM
2000 Ford Excursion
My Garage
brake shake
caliper pins are all new- were not sticking before- well lubed and no scoring. Checked all the bolts, including lug nuts- all torqued to spec.
I am wondering about ball joints etc.
  #5 (permalink)
Old 02-03-2012, 02:32 PM
LivingLarge's Avatar
LivingLarge LivingLarge is offline
LivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputation
Ball joints could cause this... I would take another look at the rotors too.
__________________
Michael
02 LTD 4X4, V10, 4.30's LS... Volant CAI, SS Banks Headers & Y-Pipe, SS Magnaflow 3" in 2x3" out, 4inch SS Tips, V codes, F350 Blocks, RAS, Helwig rear, Rancho 9000XL, Bilstein 5100 series steering stabilizer, BFG 285's, Tow Mirrors, Piaa 1500, Too much to list...
  #6 (permalink)
Old 02-03-2012, 02:50 PM
UrbanXX's Avatar
UrbanXX UrbanXX is offline
UrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputation
As LivingLarge said, Ball joints, and/or tie rod ends.
Jack up the front-end and see if you find any play or anything loose.
  #7 (permalink)
Old 02-03-2012, 03:00 PM
TrdLtly's Avatar
TrdLtly TrdLtly is offline
TrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputation
Warped Rotors?
Edit: all of my superduty's have done this at one time or another. Under heavy braking it is much worse, but light braking it is just a vibrating annoyance.
__________________
“If you think education is expensive, try ignorance.” Derek Bok -- "If you don't stand for something, you'll fall for anything." -- Are you an asset or a liability?
(aka. TreadLightly) - 1997 F250 Light Duty Base SCab 4x4 5.4L - Previous Super Dutys: 99 F250 CC LB 4x4 7.3L (220k mi), 04 F350 CC SB 4x4 6.0L (212k mi), 02 X Lmtd 4x4 v10
  #8 (permalink)
Old 02-03-2012, 04:17 PM
2000 Ford Excursion
My Garage
I would think that warped rotors would shake all the time when braking. Since this is intermittent I suspect something else.
  #9 (permalink)
Old 02-03-2012, 04:23 PM
Quote:
Not really, may brake fine on slow soft braking and also very hard braking.
Braking from highway speeds to let's say an off ramp you may feel vibrations more. Or downhill braking.
__________________
Michael
  #10 (permalink)
Old 02-03-2012, 05:51 PM
2000 Ford Excursion
My Garage
Everything is tight in the front end, however I don't like the sound of the right front wheel bearing. Has anyone ever had a bad bearing cause this type of problem- seems possible. I will tear down and report back.
  #11 (permalink)
Old 02-03-2012, 05:52 PM
2000 Ford Excursion
My Garage
Sometimes does it, sometimes not- regardless of braking pressure. Tends to smooth out under really hard braking though.
  #12 (permalink)
Old 02-03-2012, 06:10 PM
TrdLtly's Avatar
I guess that would eliminate the warped rotors as a likely cause and I would lean toward something being loose.
__________________
  #13 (permalink)
Old 02-03-2012, 07:47 PM
Wheel bearings can cause it also, I changed mine out at 154k.... Now back to the rotors!
__________________
Michael
  #14 (permalink)
Old 02-04-2012, 08:59 AM
LittleRadio LittleRadio is offline
LittleRadio is gaining momentum as a positive member of FTE.
Check your Connecting Drag Link at pitman arm. Mine is worn and causes a sort of "juggling" in the steering wheel when driving. Sometimes it's more noticeable than other times.
  #15 (permalink)
Old 02-04-2012, 11:37 AM
2000 Ford Excursion
My Garage
Pitman arm is a bit loose, so it needs replacement. I don't think this is my main problem but does need attrention. thanks for the tip LittleRadio.
Tags
2000, 2002, brake, brakes, braking, excursion, f250, ford, intermittent, rear, shake, shakes, shaking, truck, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
