The "Death Wobble"
#32
Death wobble
I'm experiencing the death wobble myself. Just lifted mine 8" on 37s, I'm sure it has encouraged it to happen. Need to get a dual steering stabilizer, and I know my ball joints are worn, it's a sketchy ride for sure. I just wanted to point out to the guys who have yet to cure yours or may not have the money to yet, but it is possible to learn or get used to driving with this issue at hand. I've learned which speeds higher or lower to avoid it, I know for sure going on or off bridges could set it off, do NOT hit any pot holes for the life of you, don't drive like it's all normal, it's not. I just get used to the fact my truck could have front end spasms at any moment in time from these driving hazards, I try n see my way around it. Although, I will be fixing it very soon. Hope this helps some guys out there, I know it's terrifying to experience this.
#33
Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles - Jeep Wrangler Forum
Above is a link to a Jeep related death wobble issue; but it is the best article I have seen on the subject. With a solid front axle, the issues will be the same. About 75% of the time, DW is related to the track bar, either the bushings are worn, or the mounting holes are elongated, or the mounting hardware is just plain loose. As shown in the link, it is best to attack the problem systematically to eliminate causes one step at a time. It isn't a Ford problem, nor a 4wd problem, but can happen with any vehicle with a solid front axle. The first time I experienced it was in a 2wd 3/4 ton IH pickup.
Personally, I would completely remove the steering stabilizer until the problem is resolved. I would then get under the vehicle with a pry bar, and start pulling and prying on everything steering / front suspension related and look for any unwanted movement and start there. Once the DW problem is resolved, then reinstall the steering stabilizer.
The best to you and yours.
#34
Death Wobble
I have a 2012 F350 Diesel with 54,000 miles on it and the death wobble has hit me. I have been to the dealership and they took air out of the tires to the point my sensor "low tire pressure" went off. The wobble hit me hard on interstate 91 in Hartford. Shhok so bad I had to slow to 10 MPH on the highway in the city with no breakdown lane.
I have contacted Ford, but getting generic responses about getting the tire pressure adjustment set at the dealership
I would like to start a class action lawsuit. This is absolutely a safety hazard.
Please send me an email at sladie42@yahoo.com with your contact info. I am not going to sit back and live with this. I spent over $50,000 on a vehicle over a year ago and cannot accept or live with this death wobble. I will contact a lawyer and see where it will go.
The question is: "Who will take on the giant"
Glenn Slade
Glenn Slade
#35
Glenn Slade
Glenn Slade
#36
Glenn Slade
Glenn Slade
Linky to what you need...
#37
In the time it took you to type that you could have gone to Amazon and ordered the cure for $75 shipped. Steering stabilizers are a wear items just like your regular shocks. You got 54,000 miles out of the first one. Not bad. Now order a premium replacement, have a Merry Christmas, and forget all the suing the giant nonsense....
Linky to what you need... Amazon.com: Bilstein 24-196284 46mm Monotube Steering Damper: Automotive
#40
#41
DW
Wow thats a great video if I was a mechanic and had a few thousand dollars worth of tools. It was very informative and would pay someone to install this stuff, but I have a 125,000 mile warranty. I am sure Ford would love to have an excuse for the wobble.
I do want to get tires and wheels, but I really need to resolve this wobble at the dealership so warranty will not be in question.
Any thoughts on the largest tire without issues. - with zero off-set Maybe a Toyo AT 305/55/20 or Nitto Terra 295/60/20.
Will lift kit void warranty on front end?
#42
Tires seemed to fix my death wobble
This past February I changed out my second set of 20" Michelin A/Ts to Michelin M/S2's. Since the change I've had no wobble or any sensation of the wobble. Prior to the change I had the truck into the dealer couple times without success. I won't claim this would be a fix for others but it sure did the trick for me.
Good luck!
Good luck!
The following users liked this post:
#43
PS: Just a thought. Ask your dealer to install a Bilstein stabilizer that you buy and supply to them. You save the work of installing it yourself. The dealer saves providing the warranty part. Win win...
#44
#45
heres my thread https://www.ford-trucks.com/forums/1...nd-bounce.html
Im thinking about replacing my shocks with some ranchos, what does the forum recommend? Pretty frustrated with ford... They already replaced my front suspension components about a month ago. Still have the death wobble. I love my truck, having said that I dont really trust that it will safely drive on the road. I won't put my family in it if its still doing this. I really don't want to get a newer truck but If this is still going to happen I have no other choice.
