VIN DECODER NEEDED - Page 2 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
VIN DECODER NEEDED
Old 09-29-2013, 12:42 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: http://www.ford-trucks.com/forums/67...-pictures.html Hey Moderators? Bob's link don't work anymore. Why?
Old 10-01-2013, 08:36 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by retired ironworker View Post
2 VINs and warranty plates. Been through a hundred posts in Large truck and no answers so here goes.
N70MU522322 / W.B. 181 / COLOR: V / MODEL: N702 / BODY: 681A / TRANS: A / AXLE: G3 / MAX GVW LBS: 23000
N70 = N700 (gas).
M = 330 2V Heavy Duty FT engine.
U = Louisville KY Assembly Plant.
522322 = 1964, assembled March 1964.
181" Wheelbase.
V = Academy Blue.
N702 = N700 (gas), 23,000 lbs. GVWR
681A: 6 = Black all Vinyl / 81A = Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
G3 = Eaton model 16802 2 Speed Rear Axle / 6.50/9.04 / 17,000 lbs. Rear Axle Capacity.
23,000 lbs. Gross Vehicle Weight Rating.
N70EVO78561 / W.B. 166 / COLOR: Blank /MODEL: N702 / BODY / 48B / TRANS: M / AXLE: M / MAX GVW LBS: 23000
N70 = LN700 (gas).
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
O78561 = 1977.
166" Wheelbase.
COLOR code: Blank ~ Truck painted a non standard color per original purchasers order.
N702 = LN700 (gas), 23,000 lbs. GVWR
48B = Black all Vinyl.
M = Clark model 285V 5 Speed Direct.
AXLE: M = Incorrect, has to be at least 2 digits.
Old 11-11-2014, 09:05 AM
jflauzier jflauzier is offline
jflauzier is starting off with a positive reputation.
1973 750 vin decode required
Hello
I would like to have more information about my 750 grain truck
here is the vin: n76fv076502
THX
Old 12-28-2014, 04:40 PM
Huey driver Huey driver is offline
Huey driver is starting off with a positive reputation.
11 digit vin needs decoding.
Here's the ID plate that needs decoding, would appreciate some help.
Data plate needs decode.
Old 12-29-2014, 06:41 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
Decoding: T91LVN73021
<table border="" cellpadding="1" cellspacing="0"><tbody><tr><th>Digit</th><th>Usage</th><th>VIN</th><th>Decoded</th></tr><tr><td>1-3</td><td>Series</td><td>T91</td><td>T900</td></tr><tr><td>4</td><td>Engine</td><td>L</td><td>Unknown!</td></tr><tr><td>5</td><td>Plant</td><td>V</td><td>Kentucky Truck</td></tr><tr><td>6-8</td><td>Mod Yr/Mfg Date</td><td>N73</td><td>1972 (Mfg Feb 1972)</td></tr><tr><td>6-11</td><td>Sequential Serial #</td><td>N73021</td><td>N73021</td></tr></tbody></table>
Old 12-29-2014, 07:13 AM
Tks Tom much appreciated.
Old 12-29-2014, 09:43 AM
i ain't rite
what engine is in that truck, a 534, or a diesel?
Old 12-29-2014, 12:14 PM
It's a 534 Tom.
534s are electric fuel pumps. Trying to cipher out a fuel problem. Pump works if I take it direct off the battery but no power off the bus bar. Fuse and lines to/from fuse box are ok. Looking for a wiring diagram now to see where that pump hot line goes.
test 1977f150xlt Testing..... 26 10-10-2015 09:11 AM
New F-150 is in GJBain 2015+ F150 44 06-04-2015 09:10 AM
1989 F250 Specs F150xlt 1987 - 1996 F150 & Larger F-Series Trucks 4 10-03-2014 07:20 AM
1957 F100 dullchrome WTB - Ford Trucks & other vehicles 3 06-01-2014 11:11 PM
please welcome Caldwell F150 jr32560 Maryland Chapter 0 05-30-2014 06:39 AM
Tags
2010, body, bronco, color, davidson, decoder, duty, ford, harley, list, model, mountaineer, needed, super, truck, vin, wb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
