New to gooseneck towing! Advice?
Hello, fellow enthusiasts! I'm new to the site, but not new to Super Dutys. Duties? Dutys...how would that be spelled?
Anyway. I have a lot of experience towing conventional trailers. 18ft @ 15k? No problem. However, I have never pulled a goose. My truck is set up for it, and I understand the concept, but I just didn't know if there was anything to look out for when I go to pick this trailer up. Is this just like anything else - just throw myself into the fire and learn it? Any advice would be appreciated. Thanks!
-Dodger
2011 F-350 6.7L Turbo Diesel
-Dodger
Depending on what type of gooseneck set-up it is, watch the clearance between the tailgate and front of the trailer when backing up to it. If it has a single center support leg make sure it is all the way up before you drive off or it will drag if you go across any kind of dip in the road. When you unhook make sure you don't forget to drop the tailgate before pulling away. I know that sounds pretty obvious but I've seen a lot of smashed tailgates from people getting in a hurry. And really heed TexasRebel's advice - swing a lot wider than you think you need to because a goose will not track anything like a bumper pull trailer. Once you get on the road, you'll be surprised at how much more stable they tow. Have fun and be safe. Welcome to FTE.
Get in a habit of making sure you have the coupler locked & safety chains hooked up if it has them. Make sure the brakes are working good. Don't forget the tailgate. Never happened to me yet but I am terrified of forgetting to put the tailgate down & pulling away after unhooking. I think the rule is 15-20% pin weight where a bumper trailer is like 10%. I have learned to look at where my overloads are and adjust to position of the load from that, just make sure you have enough pin weight. When backing the trailer into an opening for example, pull the truck past the opening & turn sharp when the trailer axles are at the opening. This will get you lined up pretty good without a bunch of maneuvering.
Towing with a gooseneck
I am towing a 12,500# (loaded) fifth wheel with a gooseneck and my 2006 F350SD Crew Cab Diesel with 8 ft bed. With the 8 ft bed, I can turn the truck almost 90 degrees to the trailer with the tailgate down and still have clearance throughout the swing. Others are right in saying that the track will be much different than a bumper mount trailer; both in forward motion turning and in backing. Advice of others on turning seems to match my experience.
My gooseneck adapter is adjustable for height. Slightly increasing the height of the trailer above the ball when connected shifted some weight to the dual axles and improved towing for me. Have noticed with a fifth wheel and gooseneck adapter that it is easy to put the bottom of the overhang down on your bed rails if you get into a situation where the truck and trailer are on uneven ground that causes one to lean more than the other. Experience will teach you how to recognize this situation and deal with it. In the meantime, just watch your mirrors carefully.
I have a short paper checklist that I use when hooking up or unhooking. I physically check off items with a pencil as I go. I have yet to damage a tailgate because I forgot to put it up or down. Some people simply remove the tailgate when they are towing for any extended period.
I also am in the habit of always checking the coupler lock handle on the cable after walking away from my truck for any reason - fuel, fuel, restroom, etc. Unfortunately, the world is full of too many jerks who would think it funny to reach over and disconnect your coupler as a joke.
I've towed about 2000 miles with mine and haven't had any problems.
Good luck.
Good luck.
I’ve pulled a 36’ gooseneck race trailer for 10 years, I just remove my tailgate. One thing I do is attach a bungee to the plug in cable & just hook the bungee to my bumper that way it doesn’t hang down too far in case you run over a retread also put a tie wrap around the plug to keep it in place.
Dave
[FONT=Calibri][SIZE=3
Dave
