E-Locker 3.55
E-Locker 3.55
2 Questions:
The Lariat I am most likely ordering only comes in the 3.55 Elocker rear end. What are the advantages and disadvantages of the E-locker? Is basically like having all wheel drive only in the rear end?
Also, do 18" Wheels have a smoother ride than 20" wheels? And can you tow more with 18 inch wheels? I ask because 17" wheels with 7 lugs comes with the max tow package.
I haven't ordered yet but I going to be really soon. Trying to collect as much info as possible.
Thanks
Thanks
For the F150s, there are three types of rear ends:
Open rear - power will be routed to the wheel that turns the easiest. Get one wheel in the mud, and you're stuck.
Limited slip - the differential has clutch packs that will transfer some of the power to the non-spinning wheel. LS is better than nothing, but has a few issues. Sometimes you may need to apply a bit of brake to get the clutches to engage. Also, fluid changes require a friction modifier - too much and the LS will never engage, too little and it will engage too often ("chattering" in hard turns) and will eventually wear the clutch packs out.
Electronic locker - the rear end operates as a standard "open" rear end normally, but you can engage the locker and lock both wheels together. When locked, the wheels will turn at the same rate, regardless of their current traction situation. The E-locker must be engaged by the driver - it is not automatic.
To me, the e-locker is better than LS or an open diff if you are going with a 2WD truck. At least you have a bit more options for getting out of a sticky situation...
But maybe I was mistaken.
18" wheels usually have a more cushioned ride than 20's because of the taller sidewalls of the tires. 20's are better for handling with less roll on curves, etc. The factory offerings of wheel/tire combos all end up being within approximately 1/2" of each other as far as total height or diameter. Some of the smaller wheels actually provide larger overall diameter than some of the 20's.
As brakes get larger, wheel sizes will get larger to properly clear the calipers and cool the brakes. It wouldn't surprise me if, eventually, 17" wheels are no longer even offered on half-tons; as manufacturers are going to look towards larger brakes for better brake feel, less fade, and decreased stopping distances.
If you've ever taken the front wheel off a new F150, you'll notice that the disk and caliper alone is larger than what used to pass for a wheel on many half-ton trucks (15").
Speaking of brakes, I'm actually amazed that an F250/F350 (13.66") has smaller front brake disks than an F150 (13.8"). You have to step up to an F450 (14.53") to get larger brakes.
Considering the new Silverado HD has 14" rotors, I'm thinking a brake size increase is coming for the Super Duty. It wouldn't surprise me if the F250/F350 gets the F450's huge 14.53" front brakes.
"Just wondering why are you getting 3.55's? Is it the EcoBoost?"
Yes, I am getting an ecoboost. I am moving from a 2002 f250 with the V10.
Thanks for the info guys. It looks like the e-locker is the way to go.
Is there a way to copy the summary of the build on the ford site and paste here? That way I can show you guys what I am thinking.
hickorycornerfarm
31
12-29-2009 08:05 PM
quisp-n-quake
17
11-03-2007 10:58 AM
