ABS light stays on - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
ABS light stays on
Old 02-02-2012, 08:45 PM
DieselVol's Avatar
DieselVol DieselVol is offline
DieselVol is gaining momentum as a positive member of FTE.
ABS light stays on
First potential issue from the 4wd conversion. The ABS light stays on constantly. The computer says no signal from either front hub. I suppose we could have 2 bad front hubs, but that seems unlikely. Another possibility is some different signal from the '06 4wd system and the '03 2wd system. Anybody got any thoughts? Thanks.
Old 02-02-2012, 08:58 PM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Just looked it up and the speed sensor s a different part between 2003 and 2006, so I think you're on the right track.
Old 02-02-2012, 09:06 PM
DieselVol's Avatar
Quote:
Is there a "frequency" difference or other info where you found that?
Old 02-02-2012, 09:18 PM
Tom's Avatar
Tom Tom is offline
Quote:
I don't really know, all I did was look up part numbers.
Old 02-02-2012, 09:24 PM
DieselVol's Avatar
Roger that. I'm thinking this may be an undefeatable wiring harness/computer issue. If we had '03 4wd speed sensors rather than '06 ones, I wonder if my '03 2wd computer would tolerate that or still see it as a problem?
Old 02-02-2012, 09:26 PM
Tom's Avatar
Tom Tom is offline
Not sure, I did PM someone that may be able to help though.
Old 02-02-2012, 09:30 PM
DieselVol's Avatar
Thanks for the help. Somebody probably knows, but these "Frankentrucks" can present problems no one has ever seen.
Old 02-02-2012, 11:15 PM
DieselVol's Avatar
Anybody know if the light being on necessarily indicates that the ABS will not work properly? Though I haven't breaked hard yet, the brakes seem to work fine.
Old 02-02-2012, 11:20 PM
Tom's Avatar
Tom Tom is offline
IIRC when the ABS light is on the system is completely disabled. You will have regular braking capability, but there will be no antilock function.
In my opinion this is worth fixing.
Old 02-02-2012, 11:24 PM
DieselVol's Avatar
I agree, but wonder if it's possible short of a whole wiring harness change. May have to involve the dreaded dealer.
Old 02-03-2012, 07:35 AM
DieselVol's Avatar
Wonder if the '03 2wd and 4wd used the same part? If so, an '03 sensor replacement should fix it.
Old 02-04-2012, 12:19 AM
DieselVol's Avatar
Turns out there is no simple solution. The plan for now is to be ABS-less unless something else turns up as an option.
ABS Trouble edsheridan Excursion - King of SUVs 1 08-25-2014 03:39 PM
04 Navigator - Advance Trac Issue talltorontoguy Expedition & Navigator 2 01-22-2014 12:05 PM
ABS Light, 4x4 Light jbtecnico1 Escape & Escape Hybrid 4 12-25-2011 12:58 PM
ABS sensor 97 dragford Expedition & Navigator 10 11-10-2010 03:28 PM
Abs light on after replacing hubs. 73cj5 Explorer, Sport Trac, Mountaineer & Aviator 1 03-19-2006 07:07 AM
Tags
02, 06, 1987, abs, diesel, duty, f150, f250, f350, ford, idi, light, stays, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
