Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #121 (permalink)
Old 02-05-2012, 02:41 PM
Scotts 7.3 Scotts 7.3 is offline
Garage is empty, add now
Scotts 7.3 is starting off with a positive reputation.
Well I pulled the IPR. Is there something else I need to do or check, valve movement, etc.? Or just put on new seals and hope it is good?
  #122 (permalink)
Old 02-05-2012, 04:41 PM
Well, nothing stuck that I could tell, just a bunch of ugly oil, so I cleaned it, put it back in. He#@$ yeah, it runs. Go figure. Thanks again to all who helped out, I couldn't have done it with out you guys, and I learned a lot more about this beast. Test drive happens now.
  #123 (permalink)
Old 02-05-2012, 05:15 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
2000 Ford F-350
BigAlsPSD is a name known to allBigAlsPSD is a name known to allBigAlsPSD is a name known to allBigAlsPSD is a name known to allBigAlsPSD is a name known to allBigAlsPSD is a name known to all
Sorry, a little late with the info, but glad to hear it was the IPR, usually just seals and check for wear on where the needle seat is.
IPR Rebuild - Large Pics.pdf
__________________
Alan 2000 F-350 CC SRW 4WD, DIY FRx, DIY CCK, Tyrant Tuning, SpringerPop's Disabler, 6637 Filter, ZooDad, Wicked Wheel, OCR, DIY Hutch Mod, Gutted EBPV, Foil Delete, 50Cent Mod, Muffler delete 277,000 Miles and counting.
Member Arkansas Chapter
Towing 2005 32' Sandpiper 5'er
  #124 (permalink)
Old 02-06-2012, 03:09 AM
Quick444's Avatar
Quick444 Quick444 is offline
Now a 3 year member :D
2001 Ford F-250
My Garage
Quick444 has a very good reputation on FTE.Quick444 has a very good reputation on FTE.Quick444 has a very good reputation on FTE.Quick444 has a very good reputation on FTE.
That 7.3 will seem as simple as the answer to 2+2 if you hang around here long enough!
__________________
-Alex- Proud Owner of "Mugly" (Click for pics)
01 F250 PSD, 296k, 4x4, CC, SB, AUTO.
Mods: DP Tuner, EGT/Boost/Trans/Oil, 5inch Exhaust, BFGs, Hawk HPS, and a ton of "can do" attitude.
  #125 (permalink)
Old 02-06-2012, 03:20 AM
b-uno's Avatar
b-uno b-uno is offline
Rep spread Extraordinaire
b-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputation
greythorn3
sounds like another thing i need to put in the glovebox! a ipr huh?
__________________
"Skip", Semper FI!
wifes 2000 Excursion limited 4x4 7.3 4R100 auto d50 sterling np tcase? "new oil and filter 195615 miles" air filter 196000 "new fuel filter 5/15/12 202500 Miles"
2nd Ultima Chinese alternator Jan 30th 2012 199226 miles, last one was Nov 26th 2010
  #126 (permalink)
Old 02-06-2012, 05:16 AM
JonathanN's Avatar
JonathanN JonathanN is offline
1999 Ford F-250
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
Quote:
Kinda expensive... $200. It'd be worth it if you don't mind it... I'd throw an ICP sensor in there along with a CPS if you don't mind spending the dough to do so. Wouldn't mind being able to do the same, either.
__________________
Jon
Early 1999 F-250 Lariat 4x4 w/7.3L PSD, AT, SC, LB, 315/75/16's on 16x10's, 4" Lift, 4" Exhaust, HPx, Regulated Fuel Return, Hutch/Harpoon, NVK4 PCM, John Wood Valve Body, 6637 w/Pete's Cover, CCV, EBPV Delete, DP-Tuner, IssPro's - 330,000 miles!
Truck Pictures
  #127 (permalink)
Old 02-06-2012, 03:19 PM
b-uno's Avatar
greythorn3
Quote:
could pull them off a junkyard 7.3 to save some cash.
__________________
"Skip", Semper FI!
  #128 (permalink)
Old 02-06-2012, 03:35 PM
JonathanN's Avatar
1999 Ford F-250
True... might do the same myself.
__________________
Jon
Truck Pictures
Tags
73, idi, schrader, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
