Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #61 (permalink)
Old 02-03-2012, 06:06 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
Garage is empty, add now
timmyboy76 has a good reputation on FTE.timmyboy76 has a good reputation on FTE.
timmyboy76 seadooya
Quote:
Originally Posted by gdunn View Post
Dose some one have a pic of the HPOP so I can check it for oil level?
1:18....LOL
__________________
TIM...PAA#113 LOTS OF PREVENTATIVE MAINT. MODS AND DIY MODS....
  #62 (permalink)
Old 02-03-2012, 06:36 PM
gdunn gdunn is offline
gdunn is starting off with a positive reputation.
Thanks. I will change this oil tomorrow!!
  #63 (permalink)
Old 02-03-2012, 06:37 PM
JonathanN's Avatar
JonathanN JonathanN is offline
1999 Ford F-250
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
Dunn,
Starting and dying sounds like O-rings... injector O-rings most likely. Is your fuel filter Black?
To the OP... need a scan tool. Pretty sure a buzz test will verify that the IDM is working. Almost sounds like a dead PCM if the IDM and ICP/IPR check out good. If it's oil, I'd be willing to bet the IPR might be stuck.
__________________
Jon
Early 1999 F-250 Lariat 4x4 w/7.3L PSD, AT, SC, LB, 315/75/16's on 16x10's, 4" Lift, 4" Exhaust, HPx, Regulated Fuel Return, Hutch/Harpoon, NVK4 PCM, John Wood Valve Body, 6637 w/Pete's Cover, CCV, EBPV Delete, DP-Tuner, IssPro's - 330,000 miles!
Truck Pictures
  #64 (permalink)
Old 02-03-2012, 06:39 PM
robbragiel's Avatar
robbragiel robbragiel is online now
robbragiel has a good reputation on FTE.robbragiel has a good reputation on FTE.robbragiel has a good reputation on FTE.
I'm with Bob (robert6401) on checking the IDM to rule it out. Its quick to do.
__________________
PAA#128 / Rob-(02 F350 Crewcab 4x4 Longbed 7.3L) Banks Power Pack System w/tri-pilar gauges, Banks Power Elbow, Banks Turbo Back Exhaust, Banks Trans Command, Banks Intercooler, Zoo-dad, HPx, FRx, CCV, AFE 6637, Hutch & Harpoon w/Dieselsite Filter kit, Trans Bypass Filter, Coolant Filter, Billet Stat Housing, Banks WW Wifes-(02 Excursion Limited 4x4 7.3L) Banks Power Elbow, Banks Turbo Back Exhaust, Banks 6 Gun Programmer, Zoo-dad, HPx, FRx, CCV, AFE 6637, Hutch & Harpoon w/dieselsite Filter, Trans Bypass Filter, Coolant Filter, Billet Stat Housing
  #65 (permalink)
Old 02-03-2012, 06:42 PM
The one in the tank was black half way up the tubes. the one on the block is still red like new. Just replaced 4 mo. ago. but the shop said the old filter was black.
  #66 (permalink)
Old 02-03-2012, 06:43 PM
Scotts 7.3 Scotts 7.3 is offline
Scotts 7.3 is starting off with a positive reputation.
I appreciate all the info and help from everyone. If I get the scanner and results, or any changes, I will be sure to post it. It may help someone else, you guys have helped me in the past , just by looking things up in older posts. Thanks to all again.
  #67 (permalink)
Old 02-03-2012, 06:45 PM
JonathanN's Avatar
1999 Ford F-250
Black filters are usually oil in fuel... this normally means bad injector O-rings causing the dirty high-pressure oil to get into the fuel (3000psi vs. 60psi... makes sense) and contaminate the filter. They've been known to go bad enough to cause a no-start when warm because the warm oil is too thin to build good enough ICP to run.
__________________
Jon
Truck Pictures
  #68 (permalink)
Old 02-03-2012, 06:46 PM
JonathanN's Avatar
1999 Ford F-250
Scott, you might be able to find a local FTE member with AE who can scan your truck and help you with reading what everything means...
__________________
Jon
Truck Pictures
  #69 (permalink)
Old 02-03-2012, 06:53 PM
That would be cool. I am in Snowflake,AZ. North eastern part of state near Showlow. Anyone in area, feel free to shout out. Havent heard about scanner from other guy yet. Still hoping.
  #70 (permalink)
Old 02-03-2012, 06:57 PM
JonathanN's Avatar
1999 Ford F-250
There's a few AZ guys on here... might could start a thread with a title that'll catch them. That and join the AZ chapter... might help.
__________________
Jon
Truck Pictures
  #71 (permalink)
Old 02-03-2012, 07:21 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
2002 Ford Excursion
My Garage
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
Here are some reference pics to help everyone out:
__________________
Nyx - 1999.5 F250 CCSB 7.3PSD Lariat, 38R, DP F5, BTS VB, 6.0 IC & tranny cooler, Kenwood DDX516 & XM radio
  #72 (permalink)
Old 02-03-2012, 11:43 PM
Robert6401's Avatar
Robert6401 Robert6401 is offline
Robert6401 has a very good reputation on FTE.Robert6401 has a very good reputation on FTE.Robert6401 has a very good reputation on FTE.
Quote:
Hi, my name is Bob. I'm suggesting you swap the IDM. If you have no one close by with a 7.3, maybe the dealer will take the IDM back if it doesn't work. That or give Swamps a call and see if they will send you one to try, its worth a shot.
__________________
-Bob-2003 F250 Lariat 7.3PSD CC SB FX4
Kwik (6637) Filter, RE leveling kit,TC Lock, EBPV/Exhaust Brake,6.0 Trans Cooler, AIH Delete, IssPro EV2 Gauges, Resurrected by Bill@PHP - tweaked by Cody (Cleatus12r), Hutch&Harpoon, Muffler Delete, WW, FRx, HPx, John Wood Trans, Swamps HV/HF IDM
  #73 (permalink)
Old 02-04-2012, 09:38 AM
Would it help to rather it up and try to start it to possibly eliminate some possibility. I know it can be bad for these engines, but I need to do something to try to eliminate the possibility of another bad cps.
  #74 (permalink)
Old 02-04-2012, 09:40 AM
That is supposed to be ether.
  #75 (permalink)
Old 02-04-2012, 10:10 AM
crop harvester crop harvester is offline
crop harvester is starting off with a positive reputation.
ether has brought a lot of heartache to diesel owners,can be very risky.
Tags
73, idi, schrader, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
