Glowshift Gauge Dimming info - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-02-2012, 06:26 PM
AllaboutMPG's Avatar
AllaboutMPG AllaboutMPG is offline
AllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to behold
So I thought that once my guages were in I would be able to use the trucks dimming switch to adjust back lighting like the trucks interior lighting. I saw a post today were another poster was having trouble with his and he had tapped into the same wire I was going to use, blue w/red stripe which is variable voltage for cab light dimming.
I called Glowshift to get the skinny. On the 7 color gauges they have a wire for dimming(orange) but its not for variable dimming. When attached to your parking light or headlight power it automatically dims the backlight by a set amount(approx 30 %) when powered. Hooking to variable with not work.
Just thought I would share this to keep someone from cutting a wire needlessly.
Side note: they also use a wire that needs to be connected to unswitched full time 12v pwr. I was a little concerned about pwr drain. Turns out this one is just for a memory circuit to remember the last color selected and is a so small a pwr user as to not be a concern.
Old 02-02-2012, 08:28 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Interesting. My ISSPRO gauges WILL dim with the factory dimmer.
Old 02-02-2012, 08:37 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
My cyberdyne will not variably dim like the dash lights they have two modes bright and kinda bright
Old 02-03-2012, 10:45 PM
xmontex4's Avatar
xmontex4 xmontex4 is offline
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
subscribing for future reference! i am looking into these gauges, how do you like em?
Old 07-14-2013, 08:36 AM
nek nek is offline
nek is starting off with a positive reputation.
nek
HI
I installed the same gauges and have used the for a month and really like them. I didn't hook up the orange wire becuse I am not sure what wire to hook them up to. MPG what wire did you end up connecting to for the night time dimming? I own a 2001 F350 PSD crew auto tran.
GlowShift boost guage ramirez7589 6.0L Power Stroke Diesel 5 04-06-2015 10:33 AM
Glowshift 3 in 1 gauge dimmer question rattleNsmoke 1999 to 2016 Super Duty 2 05-11-2014 09:09 AM
Dimming Wire for New GlowShift Gauges ChrisMelton78 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 05-08-2014 06:33 PM
Is it my alternator? DeBoerJM 6.0L Power Stroke Diesel 5 04-14-2014 08:06 PM
Which wire controls dash light brightness murraydav 6.0L Power Stroke Diesel 2 03-28-2012 03:34 PM
Tags
2001, 73, dimmer, dimming, f250, f350, gauge, gauges, glow, glowshift, guages, problems, review, shift, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
