Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Advertisement
  #1 (permalink)
Old 02-02-2012, 10:12 AM
bachus bachus is offline
Garage is empty, add now
bachus is starting off with a positive reputation.
Really stupid question for you
I'm soooo new to trucks, always had a pickup before.
05 F250 4X4 CC SWB V10.
What tire pressure should I be running?
FoMoCo says 75psi, I know that is LOADED!
What should I be running empty? Got a winter storm moving in this weekend, should I run even less for snowy roads?
Heck, I had to go out and buy a tire guage as all mine just went to 50psi.
Help out the new guy!
Dan B,
Central Ks.
  #2 (permalink)
Old 02-02-2012, 10:17 AM
barthel's Avatar
barthel barthel is offline
barthel has a good reputation on FTE.barthel has a good reputation on FTE.
JayBarthel
The best way to gauge "empty" pressure is the chalk test.
Get a piece of chalk (I use my grandaughter's sidewalk chalk) and draw a wide line across the tire tread. Then drive the truck a few feet and see how much of the chalk came off. Adjust your pressure up or down to get as much of the line off as possible.
The quicker way is visually. Let air out until the bulk of the tread looks like it's sitting flat. Then drive it and see if it's too squirrelly.
__________________
Jay
"0-60 takes 5 and a half seconds...and about 17 gallons of fuel...."
  #3 (permalink)
Old 02-02-2012, 06:33 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Barthel's method is a great way.
Tire size and construction matter a lot. My E rated 315/75-16's can have as little as 25 psi and have acceptable load capacity. A 235/85-16 D rated tire will need a lot more....
Go to the tire manufacturer's website and see if they have load capacity tables for your tire model and size. Put enough air in the front tires to support at least 2000 pounds each, and for the rear, at least 1500 pounds each and you should be pretty close to good.
__________________
'99 F250 V10 Super Cab Long Bed 4x4. '06 short block, PI conversion, modded airbox, 5 Star custom tune, FM50BB, 315/75-16 GY Duratracs, mild lift, 4.30 LSD, Ride-Rite bags, on board air, Rancho RS9000 w/MyRide, under bed subwoofer.
Why, yes, I am some kind of a geek engineer. Thank you for asking.
  #4 (permalink)
Old 02-03-2012, 08:16 AM
seville009 seville009 is offline
seville009 is starting off with a positive reputation.
I keep all four around 72psi all year, includes plowing and towing and regular old driving.
  #5 (permalink)
Old 02-03-2012, 09:38 AM
smotrs's Avatar
smotrs smotrs is offline
2008 Ford F-Super Duty
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
What does the tire say on the side? Keep in mind, tires could have been switched out for another set which may not go as high as what the door sticker says. You never want to exceed the pressure marked on the side of the tire. For instance, my tires have a max rating of 50psi but my door sticker says 65psi.
As for how much air to put in them, the chalk or grease pen test as Barthel described is the best way to find out what pressures work best for an unladen truck versus a laden truck.
__________________
Shaun
Quote:
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
  #6 (permalink)
Old 02-03-2012, 10:47 AM
dchamberlain dchamberlain is offline
dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.
Another good tire pressure test is the IR thermometer. It works best when it's warmer outside, but drive at highway speeds for awhile, then get out and measure the temperature across the surface of the tire. If it's hotter in the center than the edges, you have too much pressure. If it's hotter on the edges than in the middle, you have too little pressure. Once you figure out what pressure you need empty, remember it. Then remember if you take on a load you'll want more pressure.
If you tow a trailer or carry a specific load (like a camper) regularly, do the tests with the load and get the right pressures for that load.
FYI, running empty I find 60 PSI to be adequate, although actually it is a little high. I run stock size 265/75R16 Toyo A/T's. 55 PSI is probably closer to what I need, I just can't bring myself to run them that low. Believe it or not, my door sticker says 55 PSI front, 75 PSI rear.
__________________
David Chamberlain
2004 F-250 SD, 4x4 FX4, 6.0L PSD
Oregon Chapter Member:
To join the Oregon Chapter, click HERE
  #7 (permalink)
Old 02-03-2012, 07:20 PM
Thanks to All!
Forgot to add I'm running BFGoodrich Rugged Trails, LT265/70R17's, they list MAX as 80psi.
Was running 55psi when I got home with her, have adjusted them all to 60 for now, probably drop them back to 55 until I get the chance to do the chalk test.
Also, she was a southern truck and antifreeze was good to +5, now @ -40.
I always thought that Ford Pickups were the BEST!, but I'll never own another one. Not since I've driven a Ford Truck!
HAVE YOU DRIVEN A FORD LATLEY?!
Dan B.
Central Ks.
  #8 (permalink)
Old 02-04-2012, 08:44 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Dan B.
Central Ks.
. Hummmm.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-TRANS, DP-TUNER LIVE, MBRP 4" SS, Isspro 3 gauge kit, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #9 (permalink)
Old 02-04-2012, 09:03 AM
Sand_Man's Avatar
Sand_Man Sand_Man is offline
Sand_Man is a splendid one to beholdSand_Man is a splendid one to beholdSand_Man is a splendid one to beholdSand_Man is a splendid one to beholdSand_Man is a splendid one to beholdSand_Man is a splendid one to beholdSand_Man is a splendid one to behold
What's the difference between a pickup and a truck?
__________________
Jim-2004 Crew Cab V10 4x4
Never be afraid to try something new. Just remember, amateurs built the Ark, professionals built the Titanic...
  #10 (permalink)
Old 02-04-2012, 09:57 AM
jmiley jmiley is offline
2012 Ford F-250
jmiley is starting off with a positive reputation.
Dan B,
Central Ks.
Ford has spent millions of dollars designing the truck, their engineers know the correct pressure.
Whatever the manufacturer of the vehicle says the air pressure should be is the correct pressure.
  #11 (permalink)
Old 02-04-2012, 10:04 AM
I don't think it's that simple. The correct pressure for any given tire depends on the weight being carried by that tire. Since Ford doesn't know how much weight you're going to be carrying at any given time, it's pretty hard for them to determine the "correct pressure" at any given time. Generally the pressures they recommend are for the tires when the axle is at Gross Axle Weight Rating. Since few people are always carrying GAWR around, the correct pressure is often much less than what the sticker says.
Different tires often also requires different pressure. Again Ford can't predict what brand tire you may put on in the future, so it's impossible for them to determine the correct pressure.
Ford's recommended tire pressures are for their tires at what they figure the maximum weight should be. And I'd be willing to bet with a little extra thrown in for liability protection. If you want the best life and performance out of your tires, it's a good idea to understand tire flexing, what overpressure and underpressure does, and figure out how to determine what the correct pressure is for YOUR situation, not Ford's hypothetical one.
__________________
David Chamberlain
  #12 (permalink)
Old 02-04-2012, 10:30 AM
2012 Ford F-250
I understand there are variables in the way a vehicle is used and loads it carries, Ford and their multitude of engineers take all of that into account when designing a vehicle.
They are the ones who know how to determine the proper tire pressure.
My father was in the tire business for quite awhile, he always said to follow the automobile manufacture's advice on tire pressure, as the vehicle was designed to be run at that pressure.
Not my vehicle so I don't care what tire pressure you guys run.
  #13 (permalink)
Old 02-04-2012, 03:26 PM
Sand_Man's Avatar
What exactly did your father do in the tire business that made him feel the tire engineers weren't as trustworthy as the vehicle engineers? I'm sure Ford does have lots of engineers on staff. Those same engineers felt the 6.0 was a suitable replacement for the 7.3 and that four threads were more than enough to hold a sparkplug in place in the modular motors. Ford's engineering staff are not the last word in tires, if they were, then Ford would produce it's own tires, just like they now produce their own diesel engines
__________________
  #14 (permalink)
Old 02-04-2012, 03:35 PM
2012 Ford F-250
Quote:
The engineers at the automobile manufacturer's know more about tire pressure requirements for vehicles they design than anyone else, including internet professional's.
Tire manufacturers do not design vehicles.
The 6.0 replacing the 7.3 was due to the federal government emission standards, and you can thank uncle sam, the epa and the tree hugger's for that one.
The Ford engineers are the ones to listen to when it comes to tire pressure on vehicles they design and build, not a tire manufacturer or an internet 'guru'.
Ford does not produce a lot of parts they use, but they have to meet their specs.
My father worked for a company that sold, leased and serviced tire equipment.
  #15 (permalink)
Old 02-04-2012, 03:44 PM
2012 Ford F-250
Here is what Michelin says about tire pressure.
How To Check Tire Pressure
Compare the measured psi to the psi found on the sticker inside the driver’s door of your vehicle or in owner’s manual. DO NOT compare to the psi on your tire’s sidewall.
I think Michelin agree's what what I said as well as what my father said.
Here is what Firestone says about tire pressure.
http://www.firestonecompleteautocare...s/pressure.jsp
WHAT IS THE CORRECT PRESSURE?
The first place to look for the correct air pressure for your specific tires is your vehicle owner's manual. Correct air pressure should also be listed on the tire placard attached to the vehicle door edge, doorpost, glove box door or fuel door. You may use the tool above to view the manufacturer recommended inflations for standard sized tires on your vehicle.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
