Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Advertisement
  #31 (permalink)
Old 02-06-2012, 06:09 PM
smotrs's Avatar
smotrs smotrs is offline
2008 Ford F-Super Duty
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by bigblue61 View Post
Yikes. Clearly if the tires are only rated to 50 psi you wouldnt put 80 psi in them no matter what ANYONE would say.
Ford also claims a certain gwvr, but if you decide to put some small tires with say a 1500# load rating you obviously wouldn't think your gvwr would be the same?
Right?
Exactly. Soon as you put a tire with a lower PSI and weight rating then that spec'd by the manufacturer, you lessen the load you can safely haul/tow.
__________________
Shaun
Quote:
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
  #32 (permalink)
Old 02-06-2012, 06:33 PM
Quad Racer's Avatar
Quad Racer Quad Racer is offline
Garage is empty, add now
Quad Racer has a good reputation on FTE.Quad Racer has a good reputation on FTE.
My tires are rated for 80 psi.
Door tag says 65 psi.
I run 70 up front and 60 in the rear because the motor obviously weighs more than the truck bed. When I bought my tires I noticed how the tits were wearing to help me maintain the pressure that kept the tread the flattest. Similar to the chalk test. If I'm gonna haul anything substantial I'lkl air up the rears. I dont see why poeple run the same pressure when trucks are so loppsided with weight distribution.
I consider the "recommended" air pressures just that a recommendation. My truck, tires and life I'll do it my way. Im not gonna wear out tires prematurely because someone told me the "right" way.
__________________
08 F 250 CC V10 4.10 - 5 Star tunes (giddyup),18" XD Addicts, 295 70 18 Trail Grapplers, side marker lights
E 250 Work beast
YFZ 478 "Yes it's fast, no you can't ride it"
Jason
  #33 (permalink)
Old 02-06-2012, 07:18 PM
bigblue61's Avatar
bigblue61 bigblue61 is offline
bigblue61 is starting off with a positive reputation.
Quote:
They aren't lopsided with a load in the back. Thats why some people run the same pressures or in my case higher in the rear.
__________________
2004 F-250 Xlt Sc/lb 5.4 4x4 3.73... Toolbox, back rack, Hella Driving lights, Recon smoked cab and mirror lights, 265/75/16 Goodyear Duratracs, Flowmaster 50 series, ebay y pipe
  #34 (permalink)
Old 02-06-2012, 07:42 PM
Quad Racer's Avatar
If you have a load frequently, sure. Most of the time I have an empty box. When I tow my trailer I air up the rears.
__________________
E 250 Work beast
Jason
  #35 (permalink)
Old 02-06-2012, 10:47 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
2000 Ford F-250
My Garage
Kajtek1 has a good reputation on FTE.Kajtek1 has a good reputation on FTE.Kajtek1 has a good reputation on FTE.
Tire pressure should be adjusted to the conditions. Not only load, but that is major factor. My sedans have recommended tire pressure on fuel door with variations of the load and a note
"For speeds above 100 mph add 10 psi"
No fuel door on my Ford trucks.
__________________
e1999 F450 7.3 PowerStroke upgraded to new turbo wheel.
15,000 GVW, dump bed, 1,300 liftgate, 8,000 lb top mounted winch.
2000 F250 7.3 4x4
  #36 (permalink)
Old 02-07-2012, 11:21 AM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
What? Are you suggesting drivers should THINK and make their own decisions??? That is not acceptable by any jury in any American state. Nobody can ever be held responsible for their own actions....
And it would require owners to learn and understand something. As can be seen by many posts, that would be asking a lot for some folks.
But you are right. Too bad it is no longer acceptable.
__________________
'99 F250 V10 Super Cab Long Bed 4x4. '06 short block, PI conversion, modded airbox, 5 Star custom tune, FM50BB, 315/75-16 GY Duratracs, mild lift, 4.30 LSD, Ride-Rite bags, on board air, Rancho RS9000 w/MyRide, under bed subwoofer.
Why, yes, I am some kind of a geek engineer. Thank you for asking.
  #37 (permalink)
Old 02-07-2012, 11:34 AM
And to really put a lot of "absolute and always" statements into a tail spin....
My tires are E rated with a load capacity of 3860 lbs. With a maximum of 65 psi allowed.
And finally, how many sidewally plys do you think an E-rated tire has? If you said any more than 3, you need to try again....
__________________
  #38 (permalink)
Old 02-07-2012, 11:53 AM
Kajtek1's Avatar
2000 Ford F-250
My Garage
From the tires I have been using, I think that beside cheap trailer tires, you can't buy multiply tire for last 30 years. They use steel mesh in single layer to get the strength combined with better flexibility.
That is why new generation tires can run on low pressure for pretty long time before they disintegrate.
The ratings are still given in multiply as it usually takes over a generation to drop old habits.
Than everybody should know there is nothing wrong with riding on the max pressure the tire allows. That saves fuel with drop of comfort. I hear that some Honda owners trying to beat economy records inflate 35 psi rated tires to 50 psi with no ill effects.
__________________
2000 F250 7.3 4x4
  #39 (permalink)
Old 02-07-2012, 05:40 PM
Quad Racer's Avatar
I wish more poeple were thinking for themselves. Maybe then some of the non essential Americans could go to see Dorothy and ToTo, and leave this great country for the smarter ones to enjoy.
__________________
E 250 Work beast
Jason
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
