I'm trying to find a set of front spring shackle brackets. (what attaches the leaf spring to the frame, just in case I'm not calling it out right) Does anyone have any advice?
this may be tough to find as they are not a high demand item. if you can't locate one, find a parts truck to salvage one from. i suggest taking both sides, if possible. if that's not an option, a local fabrication shop could make some for you.
__________________
42 1.5 ton marmon herrington all wheel drive
Good photo in the Dennis Carpenter catalog.
21C-5340 for the front REAR bracket
21C-5339 for the front FRONT LEFT bracket. I think the Right is 5338
His name is Chuck Mantiglia, very nice guy. Mine cost $35 this past fall and were NOS. Came with US Army green primer on them. Only other option is to take them off and have a machine shop drill it out and put an oversize sleeve in it. Good luck...
After much searching, I found a used set of the needed brackets from a nice guy at the fordbarn forum. Got all four brackets for $50.00. Should have in the mail today. Then I can get back to work. BTW... Thanks again OregonJen for the part numbers.
