Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-02-2012, 08:48 AM
seth5051 seth5051 is offline
Garage is empty, add now
seth5051 is starting off with a positive reputation.
Drivers side catalytic converter
So, Midas says that the drivers side cat on my '08 needs to be changed out. They quote $1,000. I can find the direct fit Eastern cat online for $232. How difficult is this going to be to change out?
Im going to go ahead and change out the O2 sensors while I have it apart.
Anyone change this out? Any tips, advice?
  #2 (permalink)
Old 02-02-2012, 09:20 AM
TFWcustoms TFWcustoms is offline
TFWcustoms is starting off with a positive reputation.
I dont think it would be too hard of an install, when i Installed down pipes in my infiniti I did have to torch some bolts out but its do able. Luckily my state doesnt have state inspection and emissions every 4 years so i can get away without having catalytic converters. What are you going to do with the old one?
  #3 (permalink)
Old 02-02-2012, 03:17 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Wow! Why do they say they need to change it out? Doesn't the cat carry a longer warranty that most other items?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #4 (permalink)
Old 02-03-2012, 08:15 AM
yep, but im over the warranty period.
  #5 (permalink)
Old 02-03-2012, 08:30 AM
antony25 antony25 is offline
antony25 is starting off with a positive reputation.
80,000 mile warranty unless you have a branded title.
__________________
'06 Tahoe Z71 -----------'98 Explorer 5.0 AWD
'03 Silverado SS AWD ----'88 IROC-Z 377 TPI Megasquirt T-76
  #6 (permalink)
Old 02-03-2012, 08:50 AM
im over 80K miles
  #7 (permalink)
Old 02-03-2012, 11:17 AM
berry1234's Avatar
Why do they say it's bad? I have never trusted Midas.
__________________
  #8 (permalink)
Old 02-03-2012, 11:30 AM
I keep getting error code P0420. Had some bad plugs that were causing misfires, so I think its related.
Midas found that the temperatures out of the CAT were much hotter than the temps going into the CAT.
So, anyway - has anyone actually changed out one of these with a direct fit part? Just wondering how much of a pain its going to be.
  #9 (permalink)
Old 02-03-2012, 11:37 AM
berry1234's Avatar
The purpose of the catalytic converter is to burn any excess fuel so unburned hydrocarbons do not come out of the tailpipe and contribute to air pollution. If your engine is not functioning properly, more hydrocarbons may be making it to the converter and their combustion in the converter could be heating the exhaust. Your mechanic may be right that you need a new one (I can't examine your car from here), but I think I would look at combustion issues (fuel injection or carburetion, mixing, adequate spark, timing...) first to make sure that the real problem is not excess fuel in the exhaust. It is also possible that the exhaust is always hotter coming out of a functioning converter (I confess I don't know what "normal" is in this case - heat is normally added in the converter, but is more or less than that normally conducted out through the metal walls?) and your mechanic is either ignorant or trying to con you - get a second opinion from a reputable shop.
A good converter will usually run 100 degrees F hotter at its outlet than its inlet. Much hotter-200-500 means unburnt fuel is making its way into the exhaust.
My bet is you have fuel not being burnt. I would get a second opinion before throwing money at it.
__________________
  #10 (permalink)
Old 02-05-2012, 09:00 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Unless you have mandatory emission testing why even have a Cat?
-- Chuck
  #11 (permalink)
Old 02-14-2012, 01:37 PM
So, I decided to go with what the vehicle was telling me was wrong and ordered an Eastern passenger side direct fit catalytic converter. Went to Autozone and picked up two new O2 sensors as well.
Good thing I didnt listen to Midas, because the passenger side was obviously clogged (as in melted honeycomb).
Over all changing out the part wasnt too difficult. The catch was that the brace that supports the transmission had to come off. Once that was done it wasnt too bad. Some bolts are tough to get to, but they are reachable and same with the O2 sensor connectors.
If anyone is reading this that is wondering about the drivers side, its much easier to take off and replace.
  #12 (permalink)
Old 03-16-2012, 09:46 AM
tooldad's Avatar
tooldad tooldad is offline
tooldad is starting off with a positive reputation.
Interesting. thanks for the information. Just swapped out coils and plugs which led to a misfire on the passenger side (cracked plug) and now I keep geeting the P0420 code. Thought maybe O2 sensors, but scanner says they are okay. Am afraid the misfire sent enough unburnt fuel to the CAT that it fried. Truck seems to run fine, so I do not think I am having any current fuel delivery or misfire issues.
__________________
2006 F-150 SCREW 4x4, 20" P275/60 Michelin LTX AT2, Bedlocker, Line-X, Powergate
  #13 (permalink)
Old 03-16-2012, 09:52 AM
Tooldad - thats exactly what led up to my cat failure. Misfires from bad plugs/coils.
  #14 (permalink)
Old 03-16-2012, 10:04 AM
tooldad's Avatar
So, I had a bad plug on the passenger side that took a good while to find, with me probably putting ~20 miles on during the process. Replaced the plug and deleted the code. Drove a few days then had a (new OEM) coil go bad on the driver's side. Fixed that. Keep getting the passenger side P0420 code, but not one yet for the driver's side. Fingers crossed. The most aggravating thing is I replaced the plugs and coils chasing another problem that I thought might be a misfire, but was not, and ironically, the effort caused misfires......
__________________
  #15 (permalink)
Old 03-16-2012, 11:13 AM
berry1234's Avatar
Throwing parts at codes is costly.
__________________
Tags
2003, 2007, catalic, catalytic, change, converter, coverter, driver, drivers, expedition, f150, ford, navigator, p0420, replaced, side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
