55 F100 Dual exhausts - Ford Truck Enthusiasts Forums
Old 02-02-2012, 01:28 AM
fabieber fabieber is offline
fabieber is gaining momentum as a positive member of FTE.fabieber is gaining momentum as a positive member of FTE.
I am installing power steering on my truck. Can't figure out how to mount the power steering pump with the existing ugly crossover exhaust manifold. Don't want to spend $400 on ramhorn manifolds but don't know what other options exist.
I may be using the Toyota box but so far am leaning toward adding a power assist which uses my existing steering box. I only mention these two options in case someone knows if either box would make it possible to mount some type of manifold instead of the ramhorn.
The steering project is on hold till I can figure this out so I hope someone has good ideas and experience with this.
Thanks to all who are willing to help.
Old 02-02-2012, 10:29 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1955/57 Ford/Thenderbird 292/312 & 1958/62 292 Fords used an Eaton P/S pump. The reservoir mounts atop the pump, but on T-Birds, was remotely mounted on the left fender inner apron, due to hood clearance issues.
All 1960/62 292/352/390 Galaxies, 1963/64 289/352/390 Galaxies with A/C also have the remote mounted P/S reservoir.
Big M Automotive is located in Williams CA. Mike builds destruction derby cars, has some 1960's Fords w/292, 289/352/390 engines in his wrecking yard.
btw: 1955/57 T-Birds w/power brakes use a Hydro-Vac P/B booster, mounts on left fender inner apron. Same reason as remote P/S reservoir...hood clearance.
Old 02-02-2012, 04:25 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is online now
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
For at least 1955/56, Y-blocks in Fairlanes were dual exhaust. They sell them on EBay daily. So, you won't need to change the power steering pump at all. Jag
Old 02-02-2012, 06:31 PM
Quote:
Some were single, some were duals, cuz duals were an option.
Old 02-02-2012, 06:41 PM
Jag Red 54's Avatar
Sorry ND, but I have to disagree. All Fairlanes with a V8 were dual exhaust. I would agree with the optional status for the Mainlines and Customlines. Jag
Old 02-02-2012, 07:26 PM
'49/59 car parts catalog lists the same exhaust inlet/outlet pipes for all 1955/56 V8 Fords with single or duals, Fairlane isn't specified. The only exception are V8 Sunliners (ragtops), all came with duals.
Old 02-02-2012, 08:37 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is online now
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
Doesnt matter either way, The car manifolds for duals will not clear the steering box on the trucks. Its either rams or headers
Old 02-02-2012, 11:14 PM
Thank you guys. Anyone know if there are some ramhorns around that go for less than $400?
Fred
Old 02-02-2012, 11:34 PM
TxF100's Avatar
TxF100 TxF100 is offline
TxF100 is gaining momentum as a positive member of FTE.
Speedway sells the repo on Ebay for 379.00 plus shipping New Speedway Tru-Ram 1954-64 Y-Block Ford Exhaust Manifolds | eBay
Old 02-02-2012, 11:36 PM
Ramhorn availability
Thank you. I knew about this option and think I'm going to go with them since I haven't found any better option after looking a long time.
Old 02-03-2012, 07:57 AM
TxF100's Avatar
Quote:
I personally think the look pretty cool too, so I think they are a great option.
Old 02-03-2012, 10:14 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
I have seen duals on a 55 pickup with a second passenger side manifold turned around and installed on the driver's side. This puts the outlet at the front of the engine pointing down. Kinda weird, but it worked. I don't know if this would help your power steering issue at all.
Old 02-03-2012, 09:48 PM
dual exhaust
I have seen this done and while it looks better than using the original driver's side manifold and looping a pipe forward toward the radiator then down and to the back, the way you are suggesting still puts the exhaust pipe at an angle that interferes with the power steering pump.
I have begun to read about electric power steering pumps and would ask if anyone knnows anything about this as an option.
Thanks, guys, for your responses.
Old 03-22-2012, 12:51 PM
fnzen's Avatar
fnzen fnzen is offline
fnzen is starting off with a positive reputation.
I saw another post about Thunderbird exhaust that can be used, i cant find it now?
Ramhorn Exhaust Bolt Accessibility fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 10-04-2015 10:41 PM
Ramhorn Exhaust fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-24-2015 12:23 PM
Ramhorn Exhaust or stock fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 03-19-2015 10:03 PM
RamHorns Shadowrider123 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 20 01-16-2015 04:23 PM
Ramhorn Exhaust Manifold fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 02-17-2012 11:28 PM
Tags
1955, 292, 54, 55, 68, custom, dual, duel, exhaust, f100, power, pump, side, steering, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
