Easiest/best way to flush a heater core? - Ford Truck Enthusiasts Forums
Old 02-01-2012, 10:29 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
1991 5.8
Well the heat is working intermittently in the old beast. I'm rather convinced it's due to a nearly plugged heater core, as it will eventually start working but only after some higher RPM driving has been done.
I've never actually flushed a heater core before, but I've heard that a nozzle and a garden hose works. I've also heard of some guys using air pressure.
Recommendations? Thanks.
Old 02-01-2012, 10:32 PM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
I've used a garden hose before with some success. The key is to not use too much pressure, otherwise things can blow apart and leak. Disconnect both heater core hoses, and use the garden hose to flush water through in both directions.
Old 02-01-2012, 10:50 PM
SCRebel's Avatar
SCRebel SCRebel is offline
SCRebel is starting off with a positive reputation.
Why not just replace it? A new one is like $30. And Its not that bad to replace.
Old 02-02-2012, 04:06 AM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
tbirdscott is starting off with a positive reputation.
A garden hose isn't going to create enough pressure to harm anything. Probably just some debris in their like you assume so hose away.
SCRebel why spend more money and create more waste if you dont need to
Scott
Old 02-02-2012, 06:44 AM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Quote:
Aftermarket cores suck. I'm on my 5th one.
Old 02-02-2012, 07:58 AM
Xclimation's Avatar
Xclimation Xclimation is offline
Xclimation is starting off with a positive reputation.
X2! I paid $19.99 for mine new!. It's been working for 5 years. Flushing will not get everything out. You will also put whatever is clogging the heater core (if that's the problem) in the rest of your cooling system. Anything that will break loose will end up in your radiator, thermostat or blocking or clogging something else including shortening lifespan of water pump. We are lucky in that it is soooo easy on our trucks! If the heat is working intermittent; then your heater core is probably not plugged. It sounds like you may have an air pocket or check the vacuum hoses that control the vent doors. In particular the blend door. (I'm about to do this with mine!)
When I was less experienced on another vehicle, I tore up a dash board thinking it was the fan, or heater core. Turned out to be a five minute fix under the hood. It was a vacuum hose that ran under the battery tray. A battery had leaked a couple of years prior, damaging the vacuum hose. After giving up on the problem; 3 (yes I said 3) stealerships could NOT solve the problem! I spent a ridiculous amount of monies, time and drama! Finally took it to an auto HVAC specialist who fixed the problem, and had my ex-wifes chevy venture minivan ready within 90 minutes! The system on that minivan is same as on our trucks! (funny thing also the Corvette used the same parts as the minivan as well!) Did I mention: I HATE MINIVANS!
Old 02-02-2012, 09:49 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
did you try running a devoted ground wire to it yet?
info you should know:
http://www.awrracing.com/media/electrolysis.pdf
if you've simply had enough,take your heater core to a radiator shop and they can build you a copper brass factory replacement,but it'll likely run upwards of a hundred bucks.
Old 02-02-2012, 10:39 AM
SCRebel's Avatar
Quote:
Scott
Replacing the heater core, if its clogged, takes the trash out of the engine and its cooling system. Its very possibly to flush out the core and get it working, but then that trash might clog the radiator, or cooling passages in the engine.
I got my core from NAPA. Been running it for 6 years.
Old 02-02-2012, 02:05 PM
tbirdscott's Avatar
Ummm how? lol it is a completely separate part from the engine and rad.
If you flush it out there will be no trash in it anymore. Unless you reverse the hoses the coolant flow stays the same and the junk stays where it is.
Remove both hoses and run water through it both ways NOTHING is getting back to the rad or engine, it ends up on the ground. Completely safe, not gonna harm anything. Worst case scenario you waste 10 mins flushing it and you are back where you started.
Scott
Old 02-03-2012, 06:58 AM
DBGrif91's Avatar
Thanks for all the useful tips and discussion, guys. It's also coincidentally due for an oil change so I will probably do them at the same time.
I suspect that the heater core is plugged or at least partially blocked because up until a few weeks ago, EVERY time I would initially start and drive the truck, I could hear coolant filling the heater core. I've owned this truck for a little more than 2 years and it has always done this. Then a few weeks ago it quit, and the heat started acting up at the same time, so I'm at least going to start with a heater core flush. If that doesn't do it, then I'll move on.
Thanks again. You guys are great.
Heater core conoso 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-18-2016 08:32 AM
Radiator Flush - What's the best? redwood 1997 - 2003 F150 15 02-16-2016 05:46 PM
Heater core keeps going out wash31570 1997 - 2003 F150 4 11-30-2010 03:44 AM
heater not blowing hot air Propr801 1987 - 1996 F150 & Larger F-Series Trucks 6 12-23-2008 06:49 AM
heater not blowing hot air Propr801 Cooling, Heating, Ventilation & A/C 1 12-19-2008 07:51 PM
Tags
1991, 2001, 60, 99, b250, clean, core, dodge, duty, f150, f350, flush, ford, good, heater, ram, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
