5w30 motor oil?
Old 04-22-2003, 12:45 AM
spadetrump's Avatar
spadetrump
spadetrump is offline
Question 5w30 motor oil?
Hi,
just bought a 98 f150 with full 3 inches of chrome all the way around. its got the 4.2 v6. 48,500 k miles. runs real nice. i was wondering about the motor oil. every car i ever used i ran 10w30. the manual says to use 5w30. was wondering if anyone warns against this or has a better idea. i am in ohio. gets to be over 90 deg F in the summer and below 20 F in the winter.
Old 04-22-2003, 08:11 AM
BrianA's Avatar
BrianA
BrianA is offline
5w30 motor oil?
Glad to have you at FTE! You'll find lots of good folks and lots of good info.
I have 91,000 miles on my 2000 4.2 and have only run 10w30. The Chevron Supreme is a great oil. It is actually a Group III oil which makes it, in essence, a "synthetic". You can generally find it at Walmart for about $1.08 / qt. This is FAR less than what some comparable synthetics sell for.
Check out the Oil and Lube forum. Tons of good info there!
Agin, Welcom to FTE.
Old 04-23-2003, 12:00 PM
david00f150's Avatar
david00f150
david00f150 is offline
5w30 motor oil?
Its perfectly fine to use 10W-30. I use it in my 4.2. The 5W-30 I find is to thin.
You can never go wrong with Royal Purple, its really expensive, but its the best. If you want to go cheap, use mobil 1.
