1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 f250 v10 flexplate
Old 03-12-2021, 12:08 AM
see77777's Avatar
see77777
see77777 is offline
There’s a little notch on the 2000 f250 v10 flex plate. What is this notch referencing to align with?
Shannon
Old 03-12-2021, 09:36 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Maybe something from the manufacturing process. I don't really know but you could see the shadow on it on the crank and put it back where it was?
Maybe it only goes one way.
I'll bet thats what it is and during manufacture its easier for the techs to locate..
Old 03-12-2021, 10:10 PM
see77777's Avatar
see77777
see77777 is offline
Well it came off old seized engine and am putting it onto the new one. Trying to figure out how to position it/ if position even matters.
Old 03-12-2021, 11:32 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
See if it only goes on one way..
Old 03-13-2021, 10:01 AM
Fefanatic's Avatar
Fefanatic
Fefanatic is offline
I think you will find it will only go on one way. You will have to spin the flywheel until all bolt holes align up.
Old 03-14-2021, 06:45 PM
see77777's Avatar
see77777
see77777 is offline
ok yes blonde mistake for sure. Took a bit to sink in derp. Yes the holes won’t exactly line up until it’s at the exact right spot. 🥳🤦‍♀️ Thank you, teachers!!
darkjedi351
01-17-2021 01:01 AM
daddy4barrel
07-15-2020 10:01 PM
daddy4barrel
07-15-2020 03:24 PM
Tinman100
12-28-2015 06:34 AM
catzr440
11-23-2014 05:18 PM
Quick Reply: 2000 f250 v10 flexplate
