96 F350 Centurion
Old 02-01-2012, 05:31 PM
GPC's Avatar
GPC
GPC is offline
96 F350 Centurion
Hi y'all FORDF250HDXLT told me to come over here and see what you all think of this truck I'm thinking about buying.
It is a 1996 F350 has 7.3L Diesel with just over 300,000mi, also has freshly rebuilt transmission, along with a custom body package from Centurion. The guy that owns it is asking $4,800 for it. As best as I can tell it has no rust and needs just a little bit of cosmetic work that I can do myself.
Old 02-01-2012, 05:35 PM
fordpride's Avatar
fordpride
fordpride is offline
Buy it if not tell me where it's at
Old 02-01-2012, 06:16 PM
bad12jr's Avatar
bad12jr
bad12jr is offline
What he said^^^^
Old 02-01-2012, 06:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Wink
X3 on that. Hurry !
Old 02-01-2012, 06:31 PM
fordpride's Avatar
fordpride
While your at it here's some things to check
Turbo
You might take the air tube off the back of the air filter and look inside of it. If there is dirt build up, that is a very bad sign, so are the turbo fins looking sand blasted or bent. A little oily film is normal since the valve cover breather exits inside the tube.
Airbox:
Check the two bolts holding down the airbox lid. If they are plastic with a square recess, it is a recalled part. The recall is expired, but without the updated lid the risk of dirt infiltration is greater, the lid was updated with more supports and the updated bolts are metal with a straight slot. If it is the old style, you spend around $80 to update it.
Tranny:
If you buy a truck with an auto tranny, finding out if it's been maintained is essential, as the E4OD is an expensive transmission. Also, (if auto) seeing if the truck has an auxiliary transmission cooler would be worthwhile. For sticks, listen for clunking when shutting off or small vibration while operating. It could be an indication of a dual mass flywheel going out. Many have replaced them with single mass units.
Rear Gear Ratio:
4:10 will pull better, get slightly lower mpg�s and run a higher RPM compared to 3:55.
Coolant:
Ask the previous owner about the coolant - have they been adding FW16 or DCA4 to keep a proper SCA level? It is very important for stopping cavitation. You can get test strips to check the SCA level from NAPA, International, or Ford. I would test the current condition while looking over the truck, the SCA level should be between 1.5 and 3.0. Also, see if it has a block heater (it was an option on 97's).
Front end:
Check the front end for wear, or have an alignment shop check out the ball joints and steering linkage (tie rod ends). If they are shot, it is spendy (all four tie rods are around $400 just for parts, ball joint labor is also very spendy)
Oil:
The questions to ask are how often the oil was changed (at least every 5,000) and what kind of oil they used (diesel rated)? An oil analysis could tell you if there might be an engine problem or not.
Aftermarket stuff:
Seeing if the truck has got an aftermarket downpipe would be nice, a chip, or gauges (pyrometer, trans temp, etc.). Ask about any added items and who installed them.
Glow Plugs/Relay:
Find out if the glow plugs are in good working condition as well as the relay. Ask if either has been changed and when. You can check the glow plug resistance through the valve cover connector if needed (http://forums.ford-diesel.com/cgi-bi...&f=21&t=005210), and the relay should have power to both large terminals on top when the key is turned on, and one of the terminals should go out before ~2 minutes.
Injector o-rings:
The injector O-rings have been known to be a problem. The new o-ring sets have a pink middle seal. If the truck has an o-ring problem, one of the signs can be a discoloration of the fuel in the filter bowl. There is a drain on the passenger side front of the filter bowl for draining water (the filter is also the water separator) and you can catch some of the drained fuel in a jar � it should be dingy yellow and not blue or dark.
Leaks and Drips:
You can check the valley between the heads of the V8 for moisture and/or fluid. It should be dry not wet. Most leaks will run through this valley and down the back of the motor dripping off by the tranny/engine coupling.
VIN number:
If you take the VIN to any dealer, they can tell you when it was built, when it went into service, and some of the work that might have been done on it. You can also run prospective VIN's through Carfax.com to see the title history.
Old 02-01-2012, 10:41 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Yes, I also say buy it!
Old 02-02-2012, 06:28 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
That's a pretty nice ride, for sure. Buy it! That's a good price for a Centurian unless the motor or trans is thrashed.
Old 02-02-2012, 01:44 PM
GPC's Avatar
GPC
GPC is offline
Well I believe I'm going to try and go pick it up Monday.
Old 02-02-2012, 02:04 PM
DIYMechanic
Woo Hoo! Be sure and take lots of pictures and post them up here for us to ogle. I'm not a huge fan of the graphics and such and I like my trucks to be SRW and 4x4 but that's a nice looking pavement queen for sure. Very clean.
Old 02-02-2012, 03:01 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
he stated in another thread,that she comes with the fresh E40D receipt.
Old 02-02-2012, 03:59 PM
fordpride's Avatar
fordpride
That's a BIG +
Old 02-02-2012, 04:04 PM
Copedawg's Avatar
Copedawg
Copedawg is online now
Did you register it yet??????????
Go get it!
stick around here when you get it! It will last you 10+ years...easily! ($480 a year for nice truck like that)
Old 02-02-2012, 05:32 PM
jiveturkey692000's Avatar
jiveturkey692000
jiveturkey692000 is offline
That makes me feel warm and fuzzy in all the right places. If you dont buy that then there is something wrong with you lol
ricklee
01-05-2010 07:14 PM
strokinout
04-14-2008 07:22 PM
Quick Reply: 96 F350 Centurion
