Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1967 - 1972 F-100 & Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 02-01-2012, 11:49 AM
68Ford4Life's Avatar
68Ford4Life 68Ford4Life is offline
1968 Ford F-100
68Ford4Life is starting off with a positive reputation.
Head Swap (390-428 CJ)
so I think i have found a set of reasonably priced 428 CJ heads (125 bucks). I know they will probably need to be polished and the seats will probably need to be hardened, but I was wondering if it is worth putting these heads on my truck. I have heard people say 70 HP with headers..which sounds worth it. However, im not sure i would have everything i need. wouldn't i need new valve springs and lifters or are they pretty much a straight swap?
  #2 (permalink)
Old 02-03-2012, 08:07 AM
1968 Ford F-100
any ideas out there?
__________________
If you believe in Global Warming, you're in the wrong forum.
  #3 (permalink)
Old 02-03-2012, 08:54 AM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
1968 Ford F-100
MIKES 68 F100 is starting off with a positive reputation.
not sure about the 70hp , but make sure they are cj heads $125.00 sounds cheap
i am sure someone will chime in with cj head specs and numbers .
__________________
67 390
10:1 C/R
Lunati 62001 cam kit
home ported heads/Flotech headers
Edelbrock performer intake /Holley 750
  #4 (permalink)
Old 02-03-2012, 10:00 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Garage is empty, add now
Rogue_Wulff has a great reputation on FTE.Rogue_Wulff has a great reputation on FTE.Rogue_Wulff has a great reputation on FTE.Rogue_Wulff has a great reputation on FTE.Rogue_Wulff has a great reputation on FTE.
I seriously doubt there's 70 HP in those heads, unless the rest of the engine has some pretty serious parts installed. On a stock 68+ truck lower end, that number would be much closer to 0hp....
__________________
1980 F-150 300 I6, C6 & 9" rearend. The workhorse. 300K+
1974 F100 Ranger XLT 390, C6 3.25 axle. Dad bought it new, drove it over 500K. Now that he can no longer drive it came to me. Value: Priceless.
1983 Mazda RX7 1.1L Rotary. The show/autocross/toy. 231K
1995 Mazda B2300 (undercover Ford)
  #5 (permalink)
Old 02-03-2012, 10:42 AM
1968 Ford F-100
__________________
67 390
10:1 C/R
  #6 (permalink)
Old 02-03-2012, 05:15 PM
1968 Ford F-100
yeah, 125 is definitely cheap. I saw them on craigslist so i may go check them out. it's hard to believe it wouldn't add any horsepower though! that's hard to swallow. i always thought head work was the key to getting more hp because more air=more power. i do plan on eventually doing the 445 stroker kit..just when i have another vehicle to drive so i don't ride around in a 3 mpg beast. so i guess another question would be when i get the longer stroke would help me gain more power. and obviously a different piston type/
__________________
  #7 (permalink)
Old 02-03-2012, 05:22 PM
1968 Ford F-100
IF THEY ARE 428 CJ buy them and resell them , then you have the $$ for aluminum after market heads .
__________________
67 390
10:1 C/R
  #8 (permalink)
Old 02-03-2012, 06:04 PM
On a modified engine, they will certainly make more power. But on a stock 68+ truck engine, the gain would be practically nothing, due to the low compression ratio and cam/cam timing. When the better heads would start to come into play, the rest of the engine is pretty much done making power.
If they are truly CJ heads, and aren't junk, $125/pair would be a bargain. Well worth the investment, if the 445 kit is in your plans.
__________________
  #9 (permalink)
Old 02-03-2012, 06:20 PM
arctic y block's Avatar
arctic y block arctic y block is offline
Old School
arctic y block has much to be proud ofarctic y block has much to be proud ofarctic y block has much to be proud ofarctic y block has much to be proud ofarctic y block has much to be proud ofarctic y block has much to be proud ofarctic y block has much to be proud ofarctic y block has much to be proud ofarctic y block has much to be proud of
If you haven't put headers on yet than IMO do so. Just that one mod will make ya smile and save gas. Stock FE's can't breath and that's a fact Jack. But it don't take very much to wake them up some.
I have a free FE that needs a home. It runs fine with 40 plus oil pressure. I believe it to be a 390 but have not checked yet. It's an early one. PM me if any interest.
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Not Yet Sold
4X4 Ranger XL 90 Auto Recently Rolled Back on the road again
Don't just Modify it Fordify it
  #10 (permalink)
Old 02-04-2012, 10:02 AM
1968 Ford F-100
Quote:
haha, i like the way you think man.
__________________
  #11 (permalink)
Old 02-04-2012, 10:07 AM
1968 Ford F-100
@rogue_wulff so do you think if i were to go ahead and put those heads on there, until i complete the rest of the build-up, that they would harm anything?
__________________
  #12 (permalink)
Old 02-04-2012, 10:09 AM
1968 Ford F-100
Quote:
headers coming in march my friend! i can't wait to see (and hear) the difference.
__________________
  #13 (permalink)
Old 02-04-2012, 01:04 PM
Quote:
If you simply need replacement heads, these would work. Just don't expect much gain from them, if the rest of the engine is still in factory spec. These heads yield the best gains from an engine that has a bit more compression, and much more aggressive cam profile than what a stock 68+ truck engine has to offer.
One thing that should be noted. Larger valves tend to hurt the low end a bit, with the trade-off being more on the upper end. Larger valves, combined with "smog-era" low CR and cam specs *could* result in dismal power where it's needed the most for a daily driver type engine.
On a built 445, it would be a different story indeed.
$125/pair for true CJ heads, even just bare castings, is a rather good deal. It would cost more than this to modify basic FE heads to near CJ specs (porting & valves), but it can be done.
__________________
  #14 (permalink)
Old 02-04-2012, 08:24 PM
1968 Ford F-100
cool, well this widened my knowledge a lot guys. thanks for all the responses
__________________
Tags
1972, 390, 390428, 428, 428cj, 62001, building, cj, fe, ford, head, heads, lunati, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
