Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Sign in using an external account
Register Forgot Password?
Bronco II Ford Bronco II
  #1 (permalink)
Old 02-01-2012, 09:48 AM
spiritwild's Avatar
spiritwild spiritwild is offline
Garage is empty, add now
spiritwild is starting off with a positive reputation.
87 2.9 bII tach quit working
I unhooked the battery to test for draw and when i hooked it back up the tach quit working. is there a procedure to test for voltage from the dist/TFI or unit itself??
Also, i'll assume it may have been just a coincidental failure of the tach, cant rule it out. Everything else functions as it should, it's just the tach that has quit.
Thanks
__________________
Visit us at :
http://southernindianatrails.freehostia.com
  #2 (permalink)
Old 02-04-2012, 10:03 AM
spiritwild's Avatar
Replace the whole cluster but same issue.
i also noticed that I dont have any cluster warning/indicator lamps.
only codes i get are 21 and 24
have illumination, turn, gas guage, temp. They work.
Could this be a ground issue?
__________________
Visit us at :
  #3 (permalink)
Old 02-04-2012, 11:18 AM
Lead Head Lead Head is offline
Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.
Make sure you check all fuses, and check for any broken wires near the starter solenoid.
Also, you may get more help in the Ranger section.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #4 (permalink)
Old 02-04-2012, 02:40 PM
spiritwild's Avatar
well, I fixed it.... just not sure what i did. I had some loose/exposed wires on the alternator, taped them up and messed with the wiring harness to the cluster. not sure if it was the wires at the alt or the the wires in the harness.
either way the tach and warning lights came back on.
......but for how long i must ponder?
__________________
Visit us at :
Tags
1987, 87, dont, factory, ford, ranger, tach, tachometer, trouble, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
