finding autolite carb parts
I'm rebuilding my autolite carb 2100 series I got a rebuild kit from napa part # 2-5585 it came with everything to rebuild it but some things the brass needle is alittle shorter then the one in my carb also my carb has a plunger type thing on the top of the carb behind the choke tower the gasket bubbles out i can't find any other 2100 carbs that have it and I need that gasket the carb is out of a 71 f250 4x4 with a 360 the carb plate says it is a autolite D1TF ALA also I need a new jet mine was stripped out and needed to use a easy out where can I get a new jet size 55
I'm rebuilding my autolite carb 2100 series, I got a rebuild kit from napa part # 2-5585 it came with everything to rebuild it, but some things...
The brass needle is a little shorter then the one in my carb, also my carb has a choke pull-off diaphram on the top of the carb. The diaphram bubbles out.
I can't find any other 2100 carbs that have it (1970/74 only) and I need that diaphram.
The carb is out of a 71 F250 4x4 with a 360 the carb plate says it is a Auto-Lite D1TF-ALA
Also I need a new jet mine was stripped out and needed to use a easy out where can I get a new jet size 55
Original applications: 1970/71 F100/350 360 / 1964/72 Ford Truck Parts Catalog ~ Carb parts list # 95.30K
D4AZ-9A586-A (replaced C2AZ-9A586-B) .. 2100 Series 2V Carburetor Kit (Motorcraft CT-499-D) / Available from Ford.
Applications: ALL 2100 2V Carbs: 1962/74 Passenger Car/Truck / 1966/74 Bronco / 1969/74 Econoline.
MSRP: $33.42 // FTE Ford Dealer Parts Dept. sponsor TOUSLEYFORDPARTS.COM price: $18.30 / Tousley = White Bear Lake MN
The kit does not come w/the choke pull-off diaphram, it was only available by itself.
2) C3UZ-9533-B .. Jet #55F ~ 0-10,000 ft. (Motorcraft CJ-140) / Obsolete
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CHARAPP FORD NORTH in Natrona Heights PA has 2 = 724-294-2000.
KOVATCH FORD in Nesquehoning PA has 2 = 570-669-5118.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
KINSEL L/M in Beaumont TX has 2 = 800-816-2894.
SOEBY MOTOR CO. in Walhalla ND has 4 = 701-549-3711.
KNOWLTON FORD in Woodsfield OH has 10 = 740-472-0783.
D2AZ-9564-A (replaced C2AZ-9564-D) .. Needle & Seat (Motorcraft CV-54-A) / Obsolete
FITZPATRICK & LAMBERT in Dushore PA has 1 = 570-928-8183.
GREEN SALES CO. has 3.
KINSEL L/M has 8.
CARPENTER NOS OBSOLETE PARTS has 12.
PARTS INTERNATIONAL in Farmers Branch TX has 18 = 888-727-0418.
DOAZ-9J549-C .. Choke Pull-Off Diaphram (Motorcraft CM-1283) / Obsolete
MANDERBACH FORD in Temple PA has 1 = 610-929-3659.
KNOWLTON FORD has 1.
KINSEL L/M has 8.
GREEN SALES CO. has 17.
CARPENTER NOS OBSOLETE PARTS has 27.
PARTS INTERNATIONAL has 36.
Thanks a lot ND I went to napa and they couldn't get me any replacement jets does anyone know what the thread size is on the jets? Is the choke pull off diaphram needed? Or can I do without getting a new one? Mine has a tear where it bubbles my choke is disconnected and I have it just wired open can I use the shorter needle and seat and bend the float to compensate? Or will it make the carb operate poorly? Also the weight for the ball is thinner in the rebuild kit can I use it still as long as they weigh the same as the original? A lot of questions as this is my first carb rebuild
i may have to back off my earlier statement...holley jets fit the *early* autolites.
here's some good info:
Holley jet adapter for Autolite - Vintage Mustang Forums
joamariel
10-20-2014 12:29 AM
