February, 2012 Junk Yard Wishlist
  #31
Old 02-13-2012, 10:20 AM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Originally Posted by Festus Hagen
I am looking for a Factory Turbo Wastegated Outlet housing.
Any of you that have upgraded your factory turbo with the ATS upgrade, I would be interested in your old stock one.
Thanks
-Enjoy
fh : )_~
Still looking, it does not need to be in good shape.
If the flange is rusted out (like the one in the below link), that is perfectly fine, I can fix it!
This is what it looks like: Turbo Wastegate Housing
It's the one in the upper image on the right ... Thanks for the use of the Images Dave!
-Enjoy
fh : )_~
  #32
Old 02-14-2012, 10:17 AM
blkgolfer1's Avatar
blkgolfer1
blkgolfer1 is offline
1 barrel carb for my inline 6
I am looking for a 1 barrel carb that is low tech for my 86 F150. Anyone have one that they can part with. I assume I would need to go to a vacuum advance type distributor to go along with the setup. Thanks.
Got what I needed at pull-a-part.
  #33
Old 02-14-2012, 10:21 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Yes, you want to do a full DS2 swap, changing only half will make things worse than they are now.
  #34
Old 02-14-2012, 10:31 AM
blkgolfer1's Avatar
blkgolfer1
Any info on a "DS2" swap or pointers?
  #35
Old 02-14-2012, 10:33 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Look in the Read First Sticky
  #36
Old 02-15-2012, 11:14 AM
f100beatertruck's Avatar
f100beatertruck
f100beatertruck is offline
Looking for a clutch & brake assembly from an 83-86. I've heard those are the years with the hydraulic clutch.
I'm willing to reimburse for the JY costs, shipping as well as throw something in for some good beer and pizza.
Just PM me if you find something.
  #37
Old 02-16-2012, 06:37 AM
Skyline Drive's Avatar
Skyline Drive
Skyline Drive is offline
Need rear tank skid plates for a 84 f250.
  #38
Old 02-16-2012, 06:59 AM
fellro86's Avatar
fellro86
fellro86 is offline
How much of the system do you need? Just the pedals, or more?
  #39
Old 02-19-2012, 11:29 AM
Fastolds's Avatar
Fastolds
Fastolds is offline
I am looking for a 15" steel wheel for my 86 F150. The kind that can have a dog dish hub cap snapped over top of it.
Adam
  #40
Old 02-20-2012, 12:19 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
Still looking for some 1980-1981 351M/400 engine perches from an F-Series or a Bronco.
I found a set locally, but I have to remove a rigged 460 to get to them, and I'm worried that they might be damaged where the motor mount stud goes.
  #41
Old 02-20-2012, 07:57 PM
ratrod1923's Avatar
ratrod1923
ratrod1923 is offline
3-speed linkage
My truck is a 1981 F100 and I have the original 3-speed column in the truck but I need the linkage from the column to the tranny. Someone converted to a floor shifter but i want to go back to the original column shifter. It currently has a Hurst floor shifter that I would be willing to trade for the column linkage.
  #42
Old 02-20-2012, 09:50 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
I moved this from the "Free to a good home" thread to here, the JY Wishlist.
Thanks for the transmission ID! I will see probably tomorrow what kinds of stuff I can find at NOS parts sellers (or whoever).
  #43
Old 02-20-2012, 11:39 PM
f100beatertruck
Pedals and the aluminum under dash part. If you could get the clutch M/C that would be great but I'd settle for the pedal box & pedals.
  #44
Old 02-20-2012, 11:46 PM
fellro86's Avatar
fellro86
fellro86 is offline
Next question is how soon. I will be going in for carpal tunnel surgery, one hand, then the other, which will take me out of commission for about a month...
  #45
Old 02-21-2012, 09:03 PM
jaluhn's Avatar
jaluhn
jaluhn is offline
For Socal folks, there's a few 80-86 trucks in the Ecology yard in Chula Vista, saw a couple nice dash pieces, couple instrument clusters, etc. There's 2-3 6.9 diesel too, one still have the injection pump is anyone needs a core.
There's also a truck with a C6 2wd to Gear Vendors adapter housing out there. Someone snagged the GV overdrive that was on it but they left the adapter. That's a pretty valuable piece for someone...
Quick Reply: February, 2012 Junk Yard Wishlist
