Just ordered my coolant filter...Sinister Diesel.....Just waiting now.......Already told Kristine I am getting "gauges" with Daves assurance that it was the "best thing to do".!!!!!!!
Be careful Dale! They are ruthless about spending other peoples money on here. You've been warned.
I watched some more you tube and found one of my problems. I did replace my shock arm and shock on the Xtra 10. I mounted it in the wrong position too. That is why it is a little stiff and won't compress correctly. I do have two alum. pcs. that I removed from the rear too. The RRSS you refer to. I did not think they should be there, it limited the travel. I can put them back in tonight. I think I might get it all in stock form and hopefully get it in there. I might just have Des help too (maybe).
Ok, I got the front bolts in but...................................Now the track is too tight and I can't get the back bolts in! I checked and double checked the measurements before I put the skid in. WTF! Time for a GTG. I need to read up on this more. Is it possible that I need a different track?
Wish I could be of more help but I haven't worked on too many sleds. At least you have a little time as there doesn't seem to be too much snow in the forecast!
