Brake line flush
Brake line flush
I have a 60 f100 that is getting a new brake system, everything is being replaced but the brake lines. I am planning on flushing the existing lines out with a large syringe and colman lantern fuel. I have been told that colman fuel dries leaving no residue. Master cylinder, hoses and wheel cylinders have been removed.
Any thoughts as to a better way to do a budget flush ?
Thanks, Mark
Thanks, Mark
on
i have never heard of the coleman fuel flush. if i was doing it, i would just flush the lines with more brake fluid. something about putting a fuel in the brake line that doesnt sit well with me. if you do go with the fuel flush, i would blow them out with compressed air when you are done. might not want to be smoking when you do it.
good luck!
good luck!
The alcohol is a lot more fun, just fill the system, drain and then light a match. no more debris and it dries the system at the same time.
That sure makes me feel like a slacker! I have never flushed the lines except at replacement times. Of course, here in the lovely NE, that don't last that long anyway! They rot from the outside!
Down here it is the high humidity that gets to them. The humidity gets absorbed into the brake fluid and causes issues from within.
Through the years I have found that the more preventative maintenance you do the less you have to do in repairs.
pholmes350
13
11-30-2017 10:41 PM
Outlaw56
44
04-10-2017 09:57 AM
