Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-31-2012, 10:05 PM
Y-oh-Y's Avatar
Y-oh-Y Y-oh-Y is offline
Garage is empty, add now
Y-oh-Y is starting off with a positive reputation.
Brake line flush
I have a 60 f100 that is getting a new brake system, everything is being replaced but the brake lines. I am planning on flushing the existing lines out with a large syringe and colman lantern fuel. I have been told that colman fuel dries leaving no residue. Master cylinder, hoses and wheel cylinders have been removed.
Any thoughts as to a better way to do a budget flush ?
Thanks, Mark
  #2 (permalink)
Old 02-01-2012, 07:10 AM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
1960 Ford F-250
My Garage
thundersnow70 is starting off with a positive reputation.
i have never heard of the coleman fuel flush. if i was doing it, i would just flush the lines with more brake fluid. something about putting a fuel in the brake line that doesnt sit well with me. if you do go with the fuel flush, i would blow them out with compressed air when you are done. might not want to be smoking when you do it.
good luck!
__________________
52 F2 & F3 Merryman Herringbone
60 F250 4x4
63 F250 4x4 Flareside
Mark
I might be in a cage at the zoo, but I'm still king of the jungle!
  #3 (permalink)
Old 02-01-2012, 10:20 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
I've always used alcohol to clean brake parts. I think that is the recommended solvent. Coleman fuel (Dad called it 'white gas') is a petroleum product, and any left behind is bad for your new rubber parts. Alcohol, like coleman fuel leaves no residue. My .02
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #4 (permalink)
Old 02-01-2012, 10:35 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
1985 Ford F-150
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
theGrubbworms JoEllen Grubbs
I use denatured alcohol when I flush mine every couple of years. I get it at The Home Depot.
__________________
Dave's
1985 Ford F-150 4x2 (pictures),
4.9L 300 I6 / TOD 4spd / 8.8-3.08
Troubleshooting help, for anyone that needs it.
Reward good advice with a note by clicking the left red "Add to Reputation"
button right of the word "permalink" top right of the poster's message.
  #5 (permalink)
Old 02-01-2012, 01:27 PM
Y-oh-Y's Avatar
I thank you for your thoughts. I figgered sometimes it's better to go with whats known than to go with a maybe. Alcohol it was, worked just fine.
Thanks, Mark
  #6 (permalink)
Old 02-01-2012, 05:13 PM
Rusting-Nuts's Avatar
Rusting-Nuts Rusting-Nuts is offline
1960 Ford F-100
Rusting-Nuts is starting off with a positive reputation.
Ahhhmm....I think just using brake wash might be a good thing to use since that is what it is made for. But I'm with thundersnow70 on just using new clean brake fluid to flush the lines. I wouldn't want to contaminate the system with anything.
Good luck, Jack
  #7 (permalink)
Old 02-01-2012, 05:39 PM
Y-oh-Y's Avatar
Quote:
Good luck, Jack
The alcohol is a lot more fun, just fill the system, drain and then light a match. no more debris and it dries the system at the same time.
  #8 (permalink)
Old 02-01-2012, 08:12 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Quote:
That sure makes me feel like a slacker! I have never flushed the lines except at replacement times. Of course, here in the lovely NE, that don't last that long anyway! They rot from the outside!
  #9 (permalink)
Old 02-02-2012, 07:48 AM
Grubbworm's Avatar
1985 Ford F-150
Quote:
Down here it is the high humidity that gets to them. The humidity gets absorbed into the brake fluid and causes issues from within.
Through the years I have found that the more preventative maintenance you do the less you have to do in repairs.
__________________
Dave's
  #10 (permalink)
Old 02-02-2012, 03:43 PM
1959_f100's Avatar
1959_f100 1959_f100 is offline
1959_f100 is starting off with a positive reputation.
i would definatly re flush them with brake fluid after using anything else just to make sure you get it all out. you should not use regular shop air to flush out brakes.
Tags
04, 1966, 1985, 2004, 4x4, bleed, brake, break, f100, f150, flush, ford, issues, line, sequence
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
