Looking for a rear end for my 1960 f100 4x4
Hi, my new project is a 1960 f100 4x4. My dad was driving a while back and the axle snapped on him.Ever since then the truck has just been sitting. The truck is running so I really want to find a new rear end. I don't know if any of the other years had the same axle if so I could just switch my gears into a new housing or even better yet just find a rear end with the right gear ratio. Do any years switch over like that? My question is, do you know of any good spots where there is a ford truck graveyard around somewhere near me where i could scavenge some parts or any other ideas you have. I live in Columbia Falls mt. Or even if i could get one shipped to me that is relatively close. As far as I have heard they are pretty rare. My gear ration is 3:89.
rear end
3.89 is a common rear end for the 1/2 ton trucks. pull the axle shaft and see if it is the rear end or is the axle. Sat I found a 60 f100 4x4 in junkyard in showlow az at ShowLow Wrecking yard. if it is the axle, then they are easy to come by with a little patience. Find out if you have the 2 pin or 4 pin rear end. You want to convert to 4 pin
Marc
Marc
As the F100 had the Ford 9 inch in non limited slip applications, one from 57 to 60 would definitely fit, as would the corresponding Dana axle with limited slip from those years. It is also said that a 9 inch from an F100 through 68 would also fit. The big thing is that the spring pads on the replacement axle be the same distance apart as the old one and the end to end dimension be close to the same.
It is not too common for an axle tube to break, but I have seen it happen due to too many oferloads over time.
As number dummy said 57-67 9 inch rear axles will fit. I would look for 1/2 ton 2WD or 4Wd. only real difference is gear ratio which can be changed. Too bad you aren't closer I gave my 9 inch from my 59 4x4 to a friend. You might check Freeman Auto in Montana they have alot of older parts. Also I see a gentleman from Reygate MT has been trying to sell 57-60 truck parts for a while on e-bay or craigslist. He had some 4x4 parts for 59-60. Let us know what you find.
I put a '63 in my '60 but had to change the shock mounts. It took a little cutting and pasting but it all looks great now!
