CB vs marine VHF radio
Old 01-31-2012, 09:35 PM
CA-F250's Avatar
CA-F250
CA-F250 is offline
I am looking at buying some type of radio for communication between my f250 and other vehicals I might travel with on long trips with our fifth wheels. I had my mind set on a Midland 75-822 with a good mounted antenna. After talking with a sales rep at the local radio shop who recommended a marine VHF mounted or VHF handheld radio with roof antenna. I was told the VHF marine radios have better range and less chatter. I was hoping to get some advice on either radios and mounting recommendations or pics of intalled radios. Thanks in advance as always for the great advice.
Old 01-31-2012, 10:05 PM
cabindoc's Avatar
cabindoc
cabindoc is offline
CB will give you access to truckers and state police. vhf you will be isolated to you and your friends. And if you are within 20 miles of water, you might get the local fishermen.
Old 02-01-2012, 03:05 AM
TRENT310's Avatar
TRENT310
TRENT310 is offline
The question is do you want to talk to random people, or do you want to talk to people you specifically want to talk to?
Sometimes I want both, so I installed both my licensed 800MHz UHF radio as well as a conventional 27MHz CB. However, licenses have to be respected while traveling, and my authority to operate the radio equipment has geographical limits.
Due to its unlicensed nature, CB has become more or less a RF wasteland these days and is unreliable for serious communication, but is legally usable anywhere in Canada and the USA. Expect to deal with people broadcasting music, using too much power, and keying down for tens of minutes at a time, all in violation of regulations. (FCC Part 95, Industry Canada RIC-18)
With the licensed radios, I know I will be talking to the intended party(ies), and while others may share the frequency (simplex, not repeater), the radios have digital coded squelch enabled by default to block out other transmissions.
The frequency band characteristics of 27MHz CB make it a good performer in wide, open areas but real performance is severely degraded when obstacles are in the way, due in part to its longer wavelength, and in part due to the use of amplitude modulation, and then the widespread misuse of the radio service. A 400MHz or 800MHz FM UHF radio will have a shorter wavelength and offer good performance with obstacles, however the frequency band uses space wave propagation which requires line-of-sight and will be affected by the horizon line no matter how much power you use. The use of frequency modulation means that a lot of environmental electrical noise will not be demodulated by the receiver (since it is looking for phase angle instead of signal envelope) up until the drop-off point where the signal-to-noise ratio is insufficient for the receiver to distinguish one from the other.
While technically possible, the use of a radio on frequencies allocated to marine use inland - not on a ship, without licensing - is illegal. When using marine frequencies in a non-marine area, you will just have to license it as any VHF band commercial radio. You may not necessarily be granted such frequencies if there is any marine activity anywhere close to the area. Please respect the other users of the radio spectrum in using allocated services for their intended purpose, otherwise we have a mess that is like the citizens' band today.
This is the FCC page on use of Marine radio on land:
FCC: Wireless Services: Ship Radio Stations: Operations
Prohibited Communications
YOU MUST NOT TRANSMIT --
When your ship is on land (for example, while the ship is on a trailer).
This obviously is applicable when the vehicle is not a ship at all.
This is the Industry Canada page on use of Marine radio on land:
Licensing Exemptions - Spectrum Management and Telecommunications
Can I use maritime radio equipment on land or in my vehicle for personal use?
No, maritime radio equipment should not be operated on land or in vehicles for personal use.
Out of your two choices, CB is the only way to go. You may also consider GMRS or MURS (USA only until 2014) services.
Most trucking agencies have moved to VHF licensed radios and in many areas, multiple agencies will share the same frequencies. The VHF radios have 30-watt transmit power output and perform better than the old CB service. You may inquire with your local FCC/IC office about any 'package' frequencies that may be used in your area, and often the application for authorization for use of these frequencies will be simple as they process the 'package' often. A commercial radio dealer - not the CB shack at the nearest truck stop - may also be better prepared to answer questions on available frequencies and offer equipment options.
However, your communication depends on what the other party is using. Are you going to be outfitting everyone's vehicles with radios, or outfitting yours with an installed mobile unit and handing out handie-talkie portable units to others (as I do)? How much money, time, and effort are you willing to spend on getting radiotelephony between vehicles? How important is the proper functioning of this system to your application?
If simplicity, availability, and low cost is the goal here, then again, CB is the way to go.
Old 02-01-2012, 06:05 AM
KC8QVO's Avatar
KC8QVO
KC8QVO is offline
I won't comment much on Trents post, lots of good info in there - reread it.
My comments - you probably didn't expect to get this much info posting a "simple" question on 2 way radios. If you are after simple car-to-car, truck-to-truck communication going down the road - CB. Outside of that (short range with CB - within a mile or two) - Ham radio is your friend. There are repeaters all over the US. If you are close to one you can talk all over a state with a hand held radio. It does take a license though, not real difficult - just have to know some radio basics and regulations to pass a test. It can take a little bit for the license to be issued after your test, so this may not work well if you are in a time crunch. I'd recommend it regardless - its a great hobby. PM me if you have further questions.
Old 02-01-2012, 07:14 AM
djousma's Avatar
djousma
djousma is offline
If only wanting enough range to talk in a convoy while travelling, a handheld FRS/GMRS radio is plenty with several miles of range and can be purchased for about $50/pair. We have done that in the past. Set all radios to same channel, and security code, and you only hear each other. Honestly, anything more than that, turns into a hobby(a fun one at that).
Almost everyone in this day in age has a cellphone.
Old 02-01-2012, 07:19 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
I use my phone for this stuff now. There is an app called "HeyTell" that basically makes your smartphone behave like a walkie talkie. Very similar to the old Nextel service.
Old 02-01-2012, 12:00 PM
Davgt500's Avatar
Davgt500
Davgt500 is offline
Here is what I did with my cb and antenna. I like having a cb for finding out road conditions, where accidents have occurred, etc., but I drive my truck for a living. Good luck!
https://www.ford-trucks.com/forums/1...l#post10601780
Old 02-01-2012, 12:30 PM
lexustbs's Avatar
lexustbs
lexustbs is offline
Nice Post! Our guys only use CB raido any more when insdie quarries to communicate with the loader and scale operator. Other than that, its a bunch of trash and overpowered echo filled idiots on the air. VHF radios are the way we communicate truck to truck.
Question is, are you wanting to communicate with everybody else on the road? Or are you talking about a convoy that you just want to talk to? If its everybody then CB is your best bet
Old 02-01-2012, 11:28 PM
Rick Cargo's Avatar
Rick Cargo
Rick Cargo is offline
You can't go wrong with a Cobra 29LTD Classic. I've got mine 'tweaked and peaked' and tuned into a Wilson 1000 mag mount antenna. No problem at all getting miles down the road.
Old 02-02-2012, 12:58 AM
TRENT310's Avatar
TRENT310
TRENT310 is offline
It's one of the few fully-serviceable electronics you can still buy these days, with real through-hole components, adjustable trimpots, and variable inductors.
That's my own scanned copy but many versions are floating around on the net.
In contrast, those Motorola radios are all surface mount components, and you don't get to know how it works because that's a trade secret. The general attitude from Moto is If you can't configure it on RSS, you can't do it.
Old 02-10-2013, 06:14 PM
LongWalker's Avatar
LongWalker
LongWalker is offline
As had been mentioned. VHF-FM (Marine) use is strictly for boaters. However, I plan to use it in each vehicle. Note that near bodies of water, law enforcement MAY monitor it. FURTHER from water, it is a LESS common form of communication. AND, its reach is greater than citizens band. My intent (while improper) is to use it in abbreviated sessions, thereby reducing possibility of detection.
PS - CB is good to learn road/traffic conditions along your route. VERY much worth the effort.
Old 02-11-2013, 01:26 AM
03 SVT VERT's Avatar
03 SVT VERT
03 SVT VERT is offline
Do be aware that law enforcement rarely monitors radio frequencies for improper usage, unless it happens to interfere with public safety.
Rather, the Amateur (Ham) radio community has many members who make a hobby out of tracking and reporting improper radio usage. They treat it like a fun game, but at the same time they take illegal radio usage very seriously and can be quite tenacious in tracking down offenders. They hate unlicensed operators; as they have a lot of time and money invested in staying legal (gear, licensing, studying/taking tests, etc.)
These are the guys you would have to worry about.....and quite frankly, many of them have absolutely nothing better to do than track and report offenders. Considering the fine for a first time offense is $7,500 to $10,000 I would really think long and hard about breaking federal communications laws.
Old 02-11-2013, 08:03 AM
porthole's Avatar
porthole
porthole is offline
Easier it is to get the more abuse there will be.
Get the CB or the Family radios. FRS works pretty good and all of you in your group can have your "own" channel.
Living near the shore means half the houses have white antennas on the roof, marine VHF's.
Working for a water towing company many of us had marine radios in the house, in the trucks and plenty of portables.
Marine radios around here sometimes have as much garbage on them as CB's use to have. And one of "best" things the FCC did was allow scrambled transmissions on the marine bands.
All that really did is cause a proliferation of people not using scrambled radios to just key up, and some do that with power.
The FCC never goes after anybody on the marine bands unless we are talking hoax mayday calls. And it is the USCG that tracks and then files charges.
With Cell phones being better then ever and usage so cheap now, the abuse of marine radios has become much better.
But there is nothing like trying to monitor your working channel and having a bunch of foreign language users start chatting it for an hour or two.
Old 02-11-2013, 08:08 AM
TRENT310's Avatar
TRENT310
TRENT310 is offline
I would have at least preferred if you just did it instead of telling people on a public forum that you intend on doing it.
Yes, the marine channel plan is used near bodies of water, but away from those bodies of water those frequencies are re-allocated to commerical land mobile applications and there are still users. Don't be misled that because you're away from areas of marine radio usage that there is NO use of VHF channels. Your desired transmit channel may happen to be the receive frequency of a local repeater and you have the potential to disrupt communications in a wide area.
Old 02-11-2013, 07:32 PM
dwigmore's Avatar
dwigmore
dwigmore is offline
Motorola hand helds (frs) are cheap, work well, and have good range. Yes, lots of people have them, but you have lots of channels to choose from so traffic is seldom an issue. And it's not illegal.
Quick Reply: CB vs marine VHF radio
