starter keeps engaging (i did search) need input
Old 01-31-2012, 03:49 PM
BIGT94z's Avatar
BIGT94z
BIGT94z is offline
i have a 79' bronco that when i bought it the whole thing was wired with switches/push button. took all the wiring out and put in a factory ignition switch with key. the p.o. hacked the coil harness up to get to the coil wire (dumb) so i put a uncut coil harness on it and hooked up the s starter signal wire right. after the truck starts the starter keeps cranking until u take the s wire off the terminal. sometimes that doesnt work and i have to pull the positive battery cable (starter solenoid getting hot from troubleshooting imo) i have tried different starter, solenoid, ignition switch ect. Today i noticed once the truck is running and i pull the s wire it sill gets 8-10.5 volts all the time i know it would be simply to wire in a toggle to the s wire and be done with it but i would like it key only. where and what do i need to look for in that s wire to see why its still getting juice? i know it runs to the neutral safety switch and then to the ignition correct? where is this located?
thanks in advance guys
Old 01-31-2012, 03:59 PM
ArcadeTom's Avatar
ArcadeTom
ArcadeTom is offline
Did you check and make sure the new ignition switch is actually working properly? I have seen some older ones keep power going to the "start" position even when the key is in the "on" position.
Old 01-31-2012, 04:56 PM
BIGT94z's Avatar
BIGT94z
BIGT94z is offline
How would I test that? I have a 2nd a spare igntion switch without key/tumbler but I can't figure out how to get an old key/tumbler out of the spare complete igntion switch.
Old 01-31-2012, 05:17 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
Solenoid. But do check your connections first on it to make no wires popped off or are crossed.
Old 01-31-2012, 05:47 PM
BIGT94z's Avatar
BIGT94z
BIGT94z is offline
I have tried 3 spare solenoids. Its in that s wire wiring. I need a wiring diagram or pointed in where to look. Once u pull the s wire it stops engaging. A toggle switch on the s wire would fix it but that's mylast option imo
Old 01-31-2012, 05:48 PM
BIGT94z's Avatar
BIGT94z
BIGT94z is offline
Also starting the truck with a screw driver and the key on the on position it starts just fine hmmm lol
Old 01-31-2012, 08:58 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Originally Posted by ManfredVonRichtofen
Solenoid.
You and your solenoids. The OP clearly eliminated the solenoid by doing the following:
To the OP: Can you describe exactly what is wired where? You mentioned that you replaced the coil harness and made sure to connect the 'S' post correctly, however the coil should not connect to the 'S' post at all. However, the coil does connect to the 'I' post of the solenoid. This is the start bypass circuit to circumvent the ballast resistor when the motor is cranking over. It wouldn't surprise me if your problem is centered in this area.
Old 01-31-2012, 11:37 PM
BIGT94z's Avatar
BIGT94z
BIGT94z is offline
The brown wire is on the I terminal the s wire is the red with blue strip. Its wired right there. The coil harness was all hacked up so I got a new oem coil harnes that was plug and play. The p.o. had everthing wired to switches ( s wire, I wire, and push button start) and ran no key. There has to be smething under the dash that's wired wrong. The sensor at the brake pedal is not factory wiring but everything else is. I'm a electrical newb lol but I do know how to solder (barely) and use a multimeter lol
Old 01-31-2012, 11:49 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Red/Blue is correct for the "S" terminal and Brown is correct for "I" terminal.
Red/Blue goes to the neutral safety and then to the ignition switch. So you have some tracing to do.
Josh
Old 02-01-2012, 01:18 AM
BIGT94z's Avatar
BIGT94z
BIGT94z is offline
Can u verify where the neutral safety switch at on a 79 is?
Old 02-01-2012, 01:19 AM
BIGT94z's Avatar
BIGT94z
BIGT94z is offline
Is at* ( can't edit on mobile lol)
Old 02-01-2012, 07:44 AM
Bullitt390's Avatar
Bullitt390
Should be mounted on the transmission at the linkage.
If for some chance an older tranny was swapped in it would be on the steering column near the firewall.
Manual trans does not have a NSS
Josh
Old 02-01-2012, 02:17 PM
BIGT94z's Avatar
BIGT94z
BIGT94z is offline
Its a c6. Thanks bullitt!
William McCoy
02-04-2012 04:06 PM
sonofa75
06-07-2007 06:37 PM
K9spike
04-05-2007 12:59 PM
wideopen23
12-24-2005 06:58 PM
torquemeister
03-12-2003 12:55 PM
Quick Reply: starter keeps engaging (i did search) need input
