I just got the parking brake equalizer today, but cant get the cables strecthed enough to fit. Since its a 92, it has the automatic tensioner so i cant loosen it that way. Any one know how to replace the equalizer?
If you pull the parking brake release lever fully out and hold it there you can then pull on the single cable coming from the parking brake mechanism and extend it far enough to get the new equalizer on to all cables. Once you have it connected then let go of the release lever and the center cable should then antomatically retract and self adjust.
