Demething Bio
#31
I'm using a 4'X8' heat exchanger from an old steam boiler in an insulated box with a thermopane window, on the roof of my shop, and a smaller heat exchanger in the 500 gallon tank. I plan on using a 50/50 mix of glycerol and water for the transfer liquid.
I also plan on installing a valve set so I can transfer the heated fluid to heat the shop when I'm not using the tank.
I tried a small test last summer with a hundred foot coil of black plastic pipe on the roof of my shop, and developed 185 deg temps with a 4 gal/min flow.
#34
#36
#37
#39
#41
I know it would be more expensive but can you use magnesol to rid all the methanol out of the batch? I thought i read somewhere you can spread the used magnesol outside. If you sun dry it good you can reuse it. false claim?
If you did not demeth first, how much magnesol would use use pricewise
and
How much magnesol do you use pricewise if you demeth first
and
#42
sirnobody
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
04-23-2011 01:38 PM
Rushmore X
21
03-09-2009 09:10 AM
97biostroke
02-15-2009 01:55 PM
blkbeast
09-23-2008 03:25 PM
