Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-31-2012, 08:41 AM
mkrog mkrog is offline
Garage is empty, add now
mkrog is starting off with a positive reputation.
What radiator? 57 F100
Got 57 F100 and am looking for a new radiator,what have any body found that fit with out to much modifications.The motor is a 351C and i need the top hose in the center or left and bottom to be on the right side.
  #2 (permalink)
Old 01-31-2012, 10:34 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Mine is from a '79 toyota landcruiser wagon. Just to show you an example of using what's on hand. I think there is a kitchen sink 'p-trap' involved in the bottom hose as well. I'm hoping to find the correct radiator by next summer, so I'll be watching this thread too. Take your tape measure to a wrecking yard, I think our radiators are pretty generic looking. You might have to drill some holes in the rad or support.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #3 (permalink)
Old 02-02-2012, 09:49 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The same radiators were used 1957/60 F100/350. F350's with DRW's have a larger version.
Have y'all tried NAPA to see if they have new radiators available?
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 02-02-2012, 04:20 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
I tried NAPA for my '60 but didn't work out. Even tried ordering one for a '74 which was close but too much altering for what I wanted it to look like. I ended up getting a Cool Craft radiator from US Radiator. About two years ago the price was $360 shipped. I see things have gone up but still available for either an 8 or 6 cylinder. The following link is pointed to them for a '57. I was very pleased with their quality. They make the units as you order them right here in the South West! I really hunted around to try to save a few bucks for a couple of weeks but ended up buying from them and do not have any regrets.
Ford - Radiators Cool Craft
  #5 (permalink)
Old 02-02-2012, 05:10 PM
Thanks for the link,they are spendy.
  #6 (permalink)
Old 02-03-2012, 06:10 PM
granadojl's Avatar
granadojl granadojl is offline
1957 Ford F-100
granadojl is starting off with a positive reputation.
I'm running a Ron Davis unit and it cools like the Alaska winter. Expensive, but awesome
  #7 (permalink)
Old 02-05-2012, 04:46 PM
black58's Avatar
black58 black58 is offline
black58 is starting off with a positive reputation.
I'm running one from a mid 80's F150/Bronco. I got it for cheap at a swap meet. I didn't want to spend a small fortune for a radiator and after two, got tired of buying used ones that leaked.
Click the image to open in full size.
With the front clip on, it's really hard to tell it doesn't belong
  #8 (permalink)
Old 02-06-2012, 03:54 PM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a very good reputation on FTE.GreatNorthWoods has a very good reputation on FTE.GreatNorthWoods has a very good reputation on FTE.GreatNorthWoods has a very good reputation on FTE.
Look into a mid-70s Dodge D100 truck radiator with the 5.8 engine. This is a three row radiator and the hose connections are top center and bottom right. I'm using one in my 48 with a 350 Chevy and it works fine. It should fit your truck with a minimum of fabrication...
__________________
Vern
1949 F-1
  #9 (permalink)
Old 02-06-2012, 05:02 PM
Quote:
Thanks but I need bottom left.
  #10 (permalink)
Old 02-06-2012, 11:51 PM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
Kyle Brazier
I have a '58 with a 351 W and I got my radiator through JEGS. It's a universal aluminum 4 core radiator. I just made the measurements that I needed it to fit in and ordered one that fit those measurements. When I got it, I fabbed some simple brackets and bolted it to the pieces of steel where the original radiator went. Very simple very easy. Plus it was way cheaper than buying the one that originally went in it.
__________________
http://www.ford-trucks.com/forums/im...ine=1324186537
1958 Ford F-100. 351 W .030 over and Speed Pro flat top pistons, Comp Cams 224/226, World Windsor Sr. heads, Edelbrock Performer intake, Holley 750 carb, Roller rocker arms, Proform one-wire distributor, MSD 6-AL ignition.
  #11 (permalink)
Old 02-07-2012, 08:19 AM
Quote:
You original post says bottom right. If you need bottom left check out a 68 Ford Mustang radiator for a 390 engine. I'm using one of those for my 302 in my 49 Ford. It's a little harder to install because it's a little wide for my application but may be fine for your 57...
__________________
Vern
1949 F-1
  #12 (permalink)
Old 02-07-2012, 08:26 AM
I screwed up in my 1st. post it is left,old age is setting in.
  #13 (permalink)
Old 02-12-2012, 05:55 PM
rgs4x rgs4x is offline
rgs4x is starting off with a positive reputation.
I have seen plenty of universal aluminum radiators that will fit on ebay. Type in F100 aluminum radiator in the search bar.
  #14 (permalink)
Old 02-12-2012, 08:36 PM
spurredon's Avatar
Quote:
Many will "fit in", but will they look right. It depends what you are after I guess.
  #15 (permalink)
Old 02-12-2012, 09:51 PM
GB SISSON's Avatar
Does an aluminum radiator cool as well as copper? Are they only popular because of lower price?
__________________
Tags
100, 1956, 1957, 255, 390, 74, f100, fits, flathead, ford, napa, pickup, radiator, radiators, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
