Valley pan Turbo grommet - Ford Truck Enthusiasts Forums
Old 01-31-2012, 03:01 AM
Dodge/Cummins Dodge/Cummins is offline
Dodge/Cummins is gaining momentum as a positive member of FTE.
My TURBO gasket set has a standard (CDR) valley pan grommet which is way too large for the turbo version.
First off: does this area of the valley pan see any/much pressure? I believe the extension off of the turbo housing/mount is just a drain-back, isn't it?
I'm trying to find the old valley pan I took off which has the correct grommet but so far: no luck.
Are the valley pans different or is it just the grommet?
THANKS GUYS!
Old 01-31-2012, 08:34 AM
boggerted boggerted is offline
boggerted is starting off with a positive reputation.
ATS sells the valley pan grommet in a kit with the turbo drain orings etc. Its important to have a good seal there in case you ever have water sit in the valley or a fuel leak otherwise it will drain all that straight into the engine.
Old 01-31-2012, 08:45 AM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
Oil will leak out if there is not a good seal there(ask me how I know). When you do it, make sure you dry the area with brake parts cleaner and then use copper RTV on the grommet.
Old 02-04-2012, 03:45 PM
Brimmstone Brimmstone is offline
Brimmstone is starting off with a positive reputation.
If you are using the later 093 system Dorman part number 42344 works just fine. I believe the 088 system uses the stock grommet.
Old 02-04-2012, 11:50 PM
Quote:
The existing grommet is big enough for a N/A motor's CDR. I think my turbo system is the 093.
Old 03-07-2013, 11:46 PM
allerickb allerickb is offline
allerickb is starting off with a positive reputation.
Quote:
So is it normal for oil to be forced back out of the grommet? I in the process of doing a head of job on mine. I've removed the turbo (leaving the open grommet) now I'm getting oil filling the pan when the truck is running. So there should be a liquid tight seal there?
oiil leak derekjw Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 11-18-2014 08:21 PM
valley pan? finneys98xj 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 11-05-2011 10:06 PM
valley pan cdr hole size? kenpobuck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 03-05-2011 11:59 AM
Turbo oil drain grommet caleb6.9 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 11-30-2009 11:39 PM
93 idi factory turbo 7.3 diesel f350custom Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-18-2007 11:28 PM
Tags
093, 69, 73, 73l, 97, diesel, drain, f250, grommet, idi, instructions, leadking, oil, pan, psd, turbo, valley
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
